[QGIS-Developer] Fwd: [SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB] Version number in QGIS plugin repository wrong (Issue #2)
Roger Merritt roger at spatialtapestry.com.au
Wed Jan 8 00:05:00 PST 2025
Thanks Lova,
Made the changes, done the upload, fingers crossed.
I personally love using QGIS against PostGIS. Two amazing software products.
Regards
Roger
On Wed, Jan 8, 2025 at 3:45 PM Lova Andriarimalala via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Dear Roger,
> After checking the metadata.txt of the latest versions of VectorToDBLoader
> and landXMLtoDB_Free, I noticed that the changelog field has defined values
> but is still commented. For some reason, it confuses the workflow and the
> last word `Plugin` becomes the version instead of `1.0`. I think this
> should not be allowed (I will create an issue to add an additional check
> for this case).
> To fix the issue, I suggest uncommenting the changelog attribute like
> below (or remove the values if you don't want them to show in the plugin
> details):
> changelog=
>> 1.0: After 1000+ downloads and nothing reported, I assume all is good
>> with this plugin.
>> 1.0: https://gismart.net/stores/spatialtapestry/ is the GoTo Store for
>> more capable versions of this Plugin
> Afterwards, you can upload the updated zip files for each plugin at
> https://plugins.qgis.org/plugins/landXMLtoDB/version/Plugin/update/ and
> https://plugins.qgis.org/plugins/vectortodbloader/version/Plugin/update/.
> These processes should fix the version numbers and show the changelog on
> the specific version details page.
> PS: You can also find some notes about plugins publishing at
> https://plugins.qgis.org/publish.
> I hope this helps,
> Best regards,
> Lova Andriarimalala
> *QGIS Full Stack Developer   *
> *T *: +27(0) 87 809 2702          *E *: lova at kartoza.com          *W* :
> kartoza.com
> *This email and any attachments are confidential and intended solely for
> the use of the individual or entity to whom they are addressed. If you *
> *have received this email in error, please notify the sender immediately
> and delete it from your system. Unauthorised use, disclosure, or copying*
> *of the contents is prohibited.*
> On Wed, 8 Jan 2025 at 10:05, Lova Andriarimalala <lova at kartoza.com> wrote:
>> Dear Roger,
>> I will review the plugin and provide you with an update.
>> Best regards,
>> Lova Andriarimalala
>> kartoza.com
>> On Wed, 8 Jan 2025 at 06:52, Roger Merritt via QGIS-Developer <
>>> Hi all, any ideas on this one?
>>> ---------- Forwarded message ---------
>>> From: Roger Merritt <spatialtapestry at gmail.com>
>>> Date: Tue, Jan 7, 2025 at 11:10 AM
>>> Subject: Re: [SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB] Version
>>> To: SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB <
>>> reply+BFQN5XUOZRLUKH74VUBX746FQ52VHEVBNHHKKHFQ7E at reply.github.com>, <
>>> automation at qgis.org>
>>> My metadata.txt file has version 1.0.
>>> I cannot see anything "PLUGIN" anywhere in my files that would cause a
>>> problem.
>>> There is nothing on https://plugins.qgis.org/plugins/landXMLtoDB/update/
>>> that allows me to edit the version.
>>> I cannot find an email for zimbogisgeek to contact.
>>> I do not know how ro progress to fix this issue, sorry.
>>> If you have any ideas, please let me know.
>>> Roger
>>> On Mon, Jan 6, 2025 at 4:29 PM Michel Stuyts <notifications at github.com>
>>> wrote:
>>>> In the QGIS plugin repository the current version is called "PLUGIN"
>>>> and in the metadata it says 1.0 as version number. Because of this
>>>> difference there always seems to be an update available in QGIS, even after
>>>> updating the plugin.
>>>> Reply to this email directly, view it on GitHub
>>>> <https://github.com/SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB/issues/2>,
>>>> or unsubscribe
>>>> <https://github.com/notifications/unsubscribe-auth/BFQN5XWW5J46EU2ZPMAPP3L2JI5FHAVCNFSM6AAAAABUVEJUDCVHI2DSMVQWIX3LMV43ASLTON2WKOZSG43TAMJSGA4TKMY>
>>>> You are receiving this because you are subscribed to this thread.Message
>>>> ID: <SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB/issues/2 at github.
>>>> com>
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250108/2545f7c2/attachment.htm>
More information about the QGIS-Developer mailing list
