[QGIS-Developer] Fwd: [SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB] Version number in QGIS plugin repository wrong (Issue #2)
Lova Andriarimalala lova at kartoza.com
Wed Jan 8 00:09:02 PST 2025
My pleasure,
Thank you for the feedback.
Best regards,
Lova Andriarimalala
*QGIS Full Stack Developer   *
*T *: +27(0) 87 809 2702          *E *: lova at kartoza.com          *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Wed, 8 Jan 2025 at 11:05, Roger Merritt <roger at spatialtapestry.com.au>
wrote:
> Thanks Lova,
> Made the changes, done the upload, fingers crossed.
> I personally love using QGIS against PostGIS. Two amazing software
> products.
> Regards
> Roger
> On Wed, Jan 8, 2025 at 3:45 PM Lova Andriarimalala via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> Dear Roger,
>> After checking the metadata.txt of the latest versions of
>> VectorToDBLoader and landXMLtoDB_Free, I noticed that the changelog field
>> has defined values but is still commented. For some reason, it confuses the
>> workflow and the last word `Plugin` becomes the version instead of `1.0`. I
>> think this should not be allowed (I will create an issue to add an
>> additional check for this case).
>> To fix the issue, I suggest uncommenting the changelog attribute like
>> below (or remove the values if you don't want them to show in the plugin
>> details):
>> changelog=
>>> 1.0: After 1000+ downloads and nothing reported, I assume all is good
>>> with this plugin.
>>> 1.0: https://gismart.net/stores/spatialtapestry/ is the GoTo Store for
>>> more capable versions of this Plugin
>> Afterwards, you can upload the updated zip files for each plugin at
>> https://plugins.qgis.org/plugins/landXMLtoDB/version/Plugin/update/ and
>> https://plugins.qgis.org/plugins/vectortodbloader/version/Plugin/update/.
>> These processes should fix the version numbers and show the changelog on
>> the specific version details page.
>> PS: You can also find some notes about plugins publishing at
>> https://plugins.qgis.org/publish.
>> I hope this helps,
>> Best regards,
>> Lova Andriarimalala
>> kartoza.com
>> On Wed, 8 Jan 2025 at 10:05, Lova Andriarimalala <lova at kartoza.com>
>> wrote:
>>> Dear Roger,
>>> I will review the plugin and provide you with an update.
>>> Best regards,
>>> Lova Andriarimalala
>>> kartoza.com
>>> On Wed, 8 Jan 2025 at 06:52, Roger Merritt via QGIS-Developer <
>>>> Hi all, any ideas on this one?
>>>> ---------- Forwarded message ---------
>>>> From: Roger Merritt <spatialtapestry at gmail.com>
>>>> Date: Tue, Jan 7, 2025 at 11:10 AM
>>>> Subject: Re: [SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB]
>>>> To: SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB <
>>>> reply+BFQN5XUOZRLUKH74VUBX746FQ52VHEVBNHHKKHFQ7E at reply.github.com>, <
>>>> automation at qgis.org>
>>>> My metadata.txt file has version 1.0.
>>>> I cannot see anything "PLUGIN" anywhere in my files that would cause a
>>>> problem.
>>>> There is nothing on
>>>> https://plugins.qgis.org/plugins/landXMLtoDB/update/ that allows me to
>>>> edit the version.
>>>> I cannot find an email for zimbogisgeek to contact.
>>>> I do not know how ro progress to fix this issue, sorry.
>>>> If you have any ideas, please let me know.
>>>> Roger
>>>> On Mon, Jan 6, 2025 at 4:29 PM Michel Stuyts <notifications at github.com>
>>>> wrote:
>>>>> In the QGIS plugin repository the current version is called "PLUGIN"
>>>>> and in the metadata it says 1.0 as version number. Because of this
>>>>> difference there always seems to be an update available in QGIS, even after
>>>>> updating the plugin.
>>>>> Reply to this email directly, view it on GitHub
>>>>> <https://github.com/SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB/issues/2>,
>>>>> or unsubscribe
>>>>> <https://github.com/notifications/unsubscribe-auth/BFQN5XWW5J46EU2ZPMAPP3L2JI5FHAVCNFSM6AAAAABUVEJUDCVHI2DSMVQWIX3LMV43ASLTON2WKOZSG43TAMJSGA4TKMY>
>>>>> You are receiving this because you are subscribed to this thread.Message
>>>>> ID: <SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB/issues/2 at github
>>>>> .com>
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250108/ddab0f5e/attachment-0001.htm>
More information about the QGIS-Developer mailing list
