[QGIS-Developer] QgsJsonExporter and order
Jean Felder
jean.felder at oslandia.com
Tue Jan 21 10:14:49 PST 2025
QgsJsonExporter does not respect the attributes order. This has already
been discussed in this issue: https://github.com/qgis/QGIS/issues/41290
For example:
#!/usr/bin/env python3
from qgis.core import (QgsFeature, QgsGeometry, QgsJsonExporter, QgsPointXY,
QgsVectorLayer)
layer = QgsVectorLayer("Point?field=B:string&field=A:integer", "foo",
"memory")
feature = QgsFeature()
feature.setAttributes(["test", 123])
feature.setGeometry(QgsGeometry.fromPointXY(QgsPointXY(100, 200)))
provider = layer.dataProvider()
provider.addFeatures([feature])
exp = QgsJsonExporter(layer)
print(exp.exportFeatures(layer.getFeatures()))
The output:
{"features":[{"geometry":{"coordinates":[100.0,200.0],"type":"Point"},"id":1,"properties":{"A":123,"B":"test"},"type":"Feature"}],"type":"FeatureCollection"}
The layer has been created with the features in the order ["B", "A"].
However, QgsJsonExporter returns in the order ["A", "B"]
As answered in the issue, it is not really a bug because according to
the json specs, "The order of properties in GeoJSON isn’t defined"
However, QgsJsonExporter is used in QGIS Server and for WFS and WMS
requests.
I got some reports from users who don't understand the difference
between an xml and a json output of the same request.
Indeed, an xml request will respect the attributes order and return
["B", "A"]
A json request will not respect the attributes order and return ["A", "B"]
From a user perspective, this may look like a bug.
In fact, this "issue" comes from our usage of the "nlohmann" library
used to generate the json.
Indeed, its main object (used by QgsJsonExporter) is `nlohmann::json`
which does sort the keys by alphabetical order as explained in the
documentation.
If we want to respect the order of insertion, they provide an other
object: `nlohmann::ordered_json`
For a full explanation, see:
- https://json.nlohmann.me/features/object_order/
- https://github.com/nlohmann/json?tab=readme-ov-file#order-of-object-keys
So, a proper fix would be to remplace `nlohmann::json` by
`nlohmann::ordered_json` in all the `QgsJsonExporter` code and its caller.
From a performance point of view, I guess it would be similar to a
switch from std::map to std::unordered_map
I don't mind creating a Pull Request to change it but I would like to
know first if it would be accepted.
Any ideas or opinions?
Thanks,
Jean
Jean Felder
Développeur SIG
Oslandia
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250121/58d0bf33/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250121/58d0bf33/attachment.sig>
