[QGIS-Developer] Update plugin name
Lova Andriarimalala
lova at kartoza.com
Tue Jan 21 20:32:42 PST 2025
Dear Giacomo,
The plugin's name has been updated to 'SZ' on the web page. After several
minutes (about 15 minutes), the change will be applied to the XML list and
the QGIS Plugin Manager. You might also need to push the "Reload
Repository" button to see the change on the Plugin Manager.
Best regards.
Lova Andriarimalala
*QGIS Full Stack Developer *
*T *: +27(0) 87 809 2702 *E *: lova at kartoza.com *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Tue, 21 Jan 2025 at 18:26, Giacomo Titti via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi all,
> I recently updated the metadata of the plugin:
> https://plugins.qgis.org/plugins/sz_module . I found a mistake in the
> metadata-> name and I would change the name from 'sz_processing' to 'SZ'.
> Is it possible to also update the name in the web page and in the QGIS
> plugin list? It is still 'sz_processing'.
> Best
> Giacomo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250122/7b2de8dd/attachment.htm>
