[QGIS-Developer] 3D view bare minimum requirements
Alexandre Neto senhor.neto at gmail.com
Thu Jan 23 02:33:07 PST 2025
Hi Martin,
Thank you for your answer.
He uses windows (not sure the version) and has an ATI FireGL V graphic
card, which he wasn't able to say the correct version.
I have checked, and the most recent card of that model is from 2009, and
the most recent driver from 2015... So it's a quite old setup.
Given that OpenGL is a requirement, do you think we should add that to the
documentation both in the 3D viewer part and the working with point cloud
data?
Thanks,
Alex
A quinta, 23/01/2025, 08:23, Martin Dobias <wonder.sk at gmail.com> escreveu:
> Hi Alexandre
> As far as I can tell, besides a graphics card one just needs a system
> where OpenGL drivers are available. QGIS requests OpenGL 4.3 (or 4.1 on
> macOS, because that's the last version supported by apple).
> It would be interesting to know:
> - what is the system (win / linux / mac)
> - what is the graphics card (vendor, model)
> - what are the drivers (e.g. their version)
> - do any other OpenGL apps work (e.g. on linux try glxinfo to get
> diagnostic info, or glxgears to see spinning gears)
> Cheers
> Martin
> On Wed, Jan 22, 2025 at 11:04 PM Alexandre Neto via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> Hi,
>> Is there any known hardware or software bare minimum requirements for
>> using the 3D view or to load point clouds?
>> I have someone with an quite old graphic card where it simply doesn't
>> show anything.
>> Thanks,
>> Alex
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250123/317091e4/attachment.htm>
More information about the QGIS-Developer mailing list
