[QGIS-Developer] Deprecated plugin
Sebastian Gutwein bas at rdgland.com
Tue Jul 15 12:00:18 PDT 2025
Thanks Richard,
It does not show up in new anymore. However it also doesn't have the
Deprecated warning that I see in your screenshot.
I would think that it would be as important for people who are currently
using a plugin to know that it is depreciated as those who are wanting to
install one.
See screenshot below. An alert, like what happens with plugins with
updates, for deprecated plugins might be a good idea.
[image: image.png]
Out of curiosity where would the discussion around the issue happen? Here?
https://github.com/qgis/QGIS-Plugins-Website/issues
On Sat, Jul 12, 2025 at 4:04 AM Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 11-07-2025 16:33, Sebastian Gutwein via QGIS-Developer wrote:
> > Is there a way to determine why it was depreciated?
> Nope, I think it is a decision of the plugin maker.
> And I see you are already approaching the dev (using an issue on github).
> Another way would be to sent the dev an email (see metadata.txt on github)
> > If there was a  security issue or licensing issue would that be reported
> somewhere?
> There is security at qgis.org, but I haven't seen something about this
> plugin.
> If during the approval process 'we' discuss a licensing issue that is
> mostly discussed via an issue (and I do not see that).
> Not sure if Google would play that transparently...
> > It doesn't seem that there is any indication in the plugins manager that
> flags plugins as depreciated. Is this a security risk?
> You need to check the 'also show deprecated plugins' to actually SEE the
> plugin.
> With me then the name is grayed out and it is  very clear the plugin is
> deprecated (see screenie).
> Deprecation does not have to do anything with security, it can also be the
> coder does not want to develop the plugin anymore, or are other (personal)
> issues. (in this case, maybe Google hinted the person to it's rules about
> the user of Google services....).
> I see there is no license in the code or rep... but there should be a
> gpl-licence there, so (then) you would have been free to fork it....
> IF you did not see the plugin normally (without the 'deprication'-checkbox
> checked), but it showed up in the NEW, THAT would be an bug, I'd say...
> Regards,
___________________________
Sebastian "Bas* " Gutwein
*rhymes with Josh
Regenerative Design Group
1 Chevalier Ave
Greenfield, Ma 01301
Web: regenerativedesigngroup.com
(631) 241-1018
*Look close, think big, make change. *
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250715/cbdfe48c/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250715/cbdfe48c/attachment-0001.png>
More information about the QGIS-Developer mailing list
