[QGIS-Developer] Deprecated plugin
Lova Andriarimalala lova at kartoza.com
Wed Jul 16 23:51:24 PDT 2025
Dear Sebastian and Richard,
Sorry for the late reply.
The deprecated flag can be set mainly by the plugin's author, but I agree
with the idea of adding some notes on why it's marked as such.
Out of curiosity , where would the discussion around the issue happen?
> Here? https://github.com/qgis/QGIS-Plugins-Website/issues
Yes, that would be the main entry. Please feel free to suggest the idea
there. I can also help with creating the issue if needed (please just let
me know) and work on it later.
However, please note that this new field will probably be shown only in the
plugin's details on the website. I wonder if some modification is needed
from the plugin manager on the desktop side.
Best regards,
Lova Andriarimalala
*QGIS Full Stack Developer   *
*T *: +27(0) 87 809 2702          *E *: lova at kartoza.com          *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Tue, 15 Jul 2025 at 22:27, Sebastian Gutwein via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Thanks Richard,
> It does not show up in new anymore. However it also doesn't have the
> Deprecated warning that I see in your screenshot.
> I would think that it would be as important for people who are currently
> using a plugin to know that it is depreciated as those who are wanting to
> install one.
> See screenshot below. An alert, like what happens with plugins with
> updates, for deprecated plugins might be a good idea.
> [image: image.png]
> Out of curiosity where would the discussion around the issue happen? Here?
> On Sat, Jul 12, 2025 at 4:04 AM Richard Duivenvoorde <rdmailings at duif.net>
> wrote:
>> On 11-07-2025 16:33, Sebastian Gutwein via QGIS-Developer wrote:
>> > Is there a way to determine why it was depreciated?
>> Nope, I think it is a decision of the plugin maker.
>> And I see you are already approaching the dev (using an issue on github).
>> Another way would be to sent the dev an email (see metadata.txt on github)
>> > If there was a  security issue or licensing issue would that be
>> reported somewhere?
>> There is security at qgis.org, but I haven't seen something about this
>> plugin.
>> If during the approval process 'we' discuss a licensing issue that is
>> mostly discussed via an issue (and I do not see that).
>> Not sure if Google would play that transparently...
>> > It doesn't seem that there is any indication in the plugins manager
>> that flags plugins as depreciated. Is this a security risk?
>> You need to check the 'also show deprecated plugins' to actually SEE the
>> plugin.
>> With me then the name is grayed out and it is  very clear the plugin is
>> deprecated (see screenie).
>> Deprecation does not have to do anything with security, it can also be
>> the coder does not want to develop the plugin anymore, or are other
>> (personal) issues. (in this case, maybe Google hinted the person to it's
>> rules about the user of Google services....).
>> I see there is no license in the code or rep... but there should be a
>> gpl-licence there, so (then) you would have been free to fork it....
>> IF you did not see the plugin normally (without the
>> 'deprication'-checkbox checked), but it showed up in the NEW, THAT would be
>> an bug, I'd say...
>> Regards,
> ___________________________
> Sebastian "Bas* " Gutwein
> *rhymes with Josh
> Regenerative Design Group
> 1 Chevalier Ave
> Greenfield, Ma 01301
> Web: regenerativedesigngroup.com
> (631) 241-1018
> *Look close, think big, make change. *
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250717/d185b33f/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250717/d185b33f/attachment-0001.png>
More information about the QGIS-Developer mailing list
