[QGIS-Developer] Flatpak build experiences?
Andrea Giudiceandrea
andreaerdna at libero.it
Fri Jun 6 03:56:10 PDT 2025
Il 06/06/2025 11:48, Richard Duivenvoorde via QGIS-Developer ha scritto:
> sip-build: class 'Ui::Qgs25DRendererWidgetBase' has not been defined
> class 'Ui::QgsColorRampShaderWidgetBase' has not been defined
> class 'Ui::QgsDbSourceSelectBase' has not been defined
> class 'Ui::QgsLayerTreeEmbeddedConfigWidgetBase' has not been defined
> class 'Ui::QgsTextFormatWidgetBase' has not been defined
> class 'Ui::QgsTableWidgetUiBase' has not been defined
> class 'Ui::QgsRichTextEditorBase' has not been defined
> class 'Ui::QgsOWSSourceSelectBase' has not been defined
> class 'QgsTopologicalMesh::Changes' has not been defined
Have you already had a look at https://github.com/qgis/QGIS/issues/61951
and https://github.com/qgis/QGIS/pull/62113 ?
Regards.
Andrea
