[QGIS-Developer] Flatpak build experiences?
Richard Duivenvoorde rdmailings at duif.net
Fri Jun 6 04:01:31 PDT 2025
Argh, no sorry.
I thought it should be flatpak related because my local normal (debian) builds were fine
It's a tricky business building this beast, apparently so many moving targets underlying it...
Thanks! Will see if I can make the recipe build against master instead of a released source zip...
Regards,
On 06-06-2025 12:56, Andrea Giudiceandrea via QGIS-Developer wrote:
> Il 06/06/2025 11:48, Richard Duivenvoorde via QGIS-Developer ha scritto:
>> sip-build: class 'Ui::Qgs25DRendererWidgetBase' has not been defined
>> class 'Ui::QgsColorRampShaderWidgetBase' has not been defined
>> class 'Ui::QgsDbSourceSelectBase' has not been defined
>> class 'Ui::QgsLayerTreeEmbeddedConfigWidgetBase' has not been defined
>> class 'Ui::QgsTextFormatWidgetBase' has not been defined
>> class 'Ui::QgsTableWidgetUiBase' has not been defined
>> class 'Ui::QgsRichTextEditorBase' has not been defined
>> class 'Ui::QgsOWSSourceSelectBase' has not been defined
>> class 'QgsTopologicalMesh::Changes' has not been defined
> Have you already had a look at https://github.com/qgis/QGIS/issues/61951 and https://github.com/qgis/QGIS/pull/62113 ?
> Regards.
> Andrea
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
