[QGIS-Developer] qgis 3.40.7 fails to build with py-sip6 6.12.0
DelazJ delazj at gmail.com
Mon Jun 9 01:31:21 PDT 2025
Hi Greg,
see https://github.com/qgis/QGIS/issues/61951
Regards,
Harrissou
Le lun. 9 juin 2025 à 02:38, Greg Troxel via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> Now that I'm building a maintained version: can anyone build with
> py-sip6 6.12.0?  (With 6.10.0, 3.40 builds and runs fine.)
>   sip-build: class 'Ui::Qgs25DRendererWidgetBase' has not been defined
>   class 'Ui::QgsColorRampShaderWidgetBase' has not been defined
>   class 'Ui::QgsDbSourceSelectBase' has not been defined
>   class 'Ui::QgsLayerTreeEmbeddedConfigWidgetBase' has not been defined
>   class 'Ui::QgsTextFormatWidgetBase' has not been defined
>   class 'Ui::QgsTableWidgetUiBase' has not been defined
>   class 'Ui::QgsRichTextEditorBase' has not been defined
>   class 'Ui::QgsOWSSourceSelectBase' has not been defined
>   class 'QgsTopologicalMesh::Changes' has not been defined
>   ninja: build stopped: subcommand failed.
>   *** Error code 1
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250609/9c2b42c9/attachment.htm>
More information about the QGIS-Developer mailing list
