[QGIS-Developer] qgis 3.40.7 fails to build with py-sip6 6.12.0
Richard Duivenvoorde rdmailings at duif.net
Mon Jun 9 01:53:33 PDT 2025
Yeah, I had exactly this problem while buiding my flatpak experiment.
The lastest source zip has this issue, so I ended up just using master, which then worked
But you will problably have to wait till the next point release?
Regards,
On 09-06-2025 10:31, DelazJ via QGIS-Developer wrote:
> Hi Greg,
> see https://github.com/qgis/QGIS/issues/61951 <https://github.com/qgis/QGIS/issues/61951>
> Regards,
> Harrissou
> Le lun. 9 juin 2025 à 02:38, Greg Troxel via QGIS-Developer <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>> a écrit :
>     Now that I'm building a maintained version: can anyone build with
>     py-sip6 6.12.0?  (With 6.10.0, 3.40 builds and runs fine.)
>        sip-build: class 'Ui::Qgs25DRendererWidgetBase' has not been defined
>        class 'Ui::QgsColorRampShaderWidgetBase' has not been defined
>        class 'Ui::QgsDbSourceSelectBase' has not been defined
>        class 'Ui::QgsLayerTreeEmbeddedConfigWidgetBase' has not been defined
>        class 'Ui::QgsTextFormatWidgetBase' has not been defined
>        class 'Ui::QgsTableWidgetUiBase' has not been defined
>        class 'Ui::QgsRichTextEditorBase' has not been defined
>        class 'Ui::QgsOWSSourceSelectBase' has not been defined
>        class 'QgsTopologicalMesh::Changes' has not been defined
>        ninja: build stopped: subcommand failed.
>        *** Error code 1
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
More information about the QGIS-Developer mailing list
