[QGIS-Developer] closed PR
Tim Sutton tim at kartoza.com
Wed Jun 11 12:54:25 PDT 2025
Hi Moritz
I see Even has reopened it for you. Just bear in mind that unless you are
working for a commercial project and can pay a reviewer to review your
PR's, you will be relying on the good will of a developer who may or may
not have time to review your PR. You may need to be gently persistent and
patient, along with a little social engineering to get your PR reviewed and
merged.
Regards
Tim
On Tue, Jun 10, 2025 at 1:01 PM Moritz Hackenberg via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hello,
> I have a general question about pull requests: What can I do about a PR
> getting the label stale and then getting closed? I have this one, for
> example:
> https://github.com/qgis/QGIS/pull/61706
> Nyall Dawson had put a Freeze Exempt Label on it, so I suppose I wasn't
> total nonsense :).
>   Is that just the way it goes, and one is just out of luck if no one
> approves in time? Should I make a new identical PR, or could it be
> reopened?
> best wishes from Portugal
> Moritz
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
*Kartoza Cofounder*Tim is a member of the QGIS Project Steering Committee
*T *: +27(0) 87 809 2702          *E *: tim at kartoza.com          *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250611/0cb420ac/attachment.htm>
More information about the QGIS-Developer mailing list
