[QGIS-Developer] Experimental Qt6 Flatpak build available for Linux/Python devs (for updating plugins)
Richard Duivenvoorde rdmailings at duif.net
Wed Jun 11 07:48:19 PDT 2025
Based on the excellent Flatpak work of Aleix Pol (https://github.com/flathub/org.qgis.qgis), I managed to create a runnable Qt6 build of QGIS for Linux's (with flatpak available)
My idea is that Linux users of distro's without the needed dependencies can run QGIS and test/update their Python plugins with this build.
This flatpak build (master) is (thanks to Aleix!) having 3D and PDAL/cloudpoint available too.
Note that this is my first flatpak build, probably things go/are wrong, and I'm not sure how to do further/future distribution...
But for now: to run/try it:
Download the single-bundle file from
http://duif.net/qgis-qt6.flatpak
If you do not have flatpak/flathub available, make sure you do by doing the steps at
https://flatpak.org/setup/ for your distro, to
1) install flatpak and
2) make the flathub repo available for needed runtimes and sdk's.
Now go to the qgis-qt6.flatpak file and INSTALL it:
flatpak install --runtime --include-sdk qgis-qt6.flatpak
(this will install the KDE runtime and sdk and then finally the qgis-qt6 system wide)
Then to run it:
flatpak run org.qgis.qgis
I hope this is useful for anybody.
Have to talk to Aleix for more finesses to maybe share this on flathub or with his Qt5 build.
If you want to build it yourself there is some info in: https://github.com/flathub/org.qgis.qgis/issues/428
Regards,
More information about the QGIS-Developer mailing list
