[QGIS-Developer] Experimental Qt6 Flatpak build available for Linux/Python devs (for updating plugins)
Germán Carrillo carrillo.german at gmail.com
Wed Jun 11 09:08:30 PDT 2025
Thanks a lot Richard and Aleix, it works like a charm on Ubuntu Noble.
Regards,
Germán
El mié, 11 jun 2025 a las 10:02, Richard Duivenvoorde via QGIS-Developer (<
qgis-developer at lists.osgeo.org>) escribió:
> Hi,
> Based on the excellent Flatpak work of Aleix Pol (
> https://github.com/flathub/org.qgis.qgis), I managed to create a runnable
> Qt6 build of QGIS for Linux's (with flatpak available)
> My idea is that Linux users of distro's without the needed dependencies
> can run QGIS and test/update their Python plugins with this build.
> This flatpak build (master) is (thanks to Aleix!) having 3D and
> PDAL/cloudpoint available too.
> Note that this is my first flatpak build, probably things go/are wrong,
> and I'm not sure how to do further/future distribution...
> But for now: to run/try it:
> Download the single-bundle file from
> http://duif.net/qgis-qt6.flatpak
> If you do not have flatpak/flathub available, make sure you do by doing
> the steps at
> https://flatpak.org/setup/ for your distro, to
> 1) install flatpak and
> 2) make the flathub repo available for needed runtimes and sdk's.
> Now go to the qgis-qt6.flatpak file and INSTALL it:
> flatpak install --runtime --include-sdk qgis-qt6.flatpak
> (this will install the KDE runtime and sdk and then finally the qgis-qt6
> system wide)
> Then to run it:
> flatpak run org.qgis.qgis
> I hope this is useful for anybody.
> Have to talk to Aleix for more finesses to maybe share this on flathub or
> with his Qt5 build.
> If you want to build it yourself there is some info in:
> https://github.com/flathub/org.qgis.qgis/issues/428
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250611/1752c790/attachment.htm>
More information about the QGIS-Developer mailing list
