[QGIS-Developer] Experimental Qt6 Flatpak build available for Linux/Python devs (for updating plugins)
Tim Sutton
tim at kartoza.com
Wed Jun 11 12:47:07 PDT 2025
Hi Richard
Very nice to see this! I tried to download it though and it seems to not
open the link. I will test on NixOS....
Regards
Tim
On Wed, Jun 11, 2025 at 5:08 PM Germán Carrillo via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi,
> Thanks a lot Richard and Aleix, it works like a charm on Ubuntu Noble.
> Regards,
> Germán
> El mié, 11 jun 2025 a las 10:02, Richard Duivenvoorde via QGIS-Developer (<
> qgis-developer at lists.osgeo.org>) escribió:
>> Hi,
>> Based on the excellent Flatpak work of Aleix Pol (
>> https://github.com/flathub/org.qgis.qgis), I managed to create a
>> runnable Qt6 build of QGIS for Linux's (with flatpak available)
>> My idea is that Linux users of distro's without the needed dependencies
>> can run QGIS and test/update their Python plugins with this build.
>> This flatpak build (master) is (thanks to Aleix!) having 3D and
>> PDAL/cloudpoint available too.
>> Note that this is my first flatpak build, probably things go/are wrong,
>> and I'm not sure how to do further/future distribution...
>> But for now: to run/try it:
>> Download the single-bundle file from
>> http://duif.net/qgis-qt6.flatpak
>> If you do not have flatpak/flathub available, make sure you do by doing
>> the steps at
>> https://flatpak.org/setup/ for your distro, to
>> 1) install flatpak and
>> 2) make the flathub repo available for needed runtimes and sdk's.
>> Now go to the qgis-qt6.flatpak file and INSTALL it:
>> flatpak install --runtime --include-sdk qgis-qt6.flatpak
>> (this will install the KDE runtime and sdk and then finally the qgis-qt6
>> system wide)
>> Then to run it:
>> flatpak run org.qgis.qgis
>> I hope this is useful for anybody.
>> Have to talk to Aleix for more finesses to maybe share this on flathub or
>> with his Qt5 build.
>> If you want to build it yourself there is some info in:
>> https://github.com/flathub/org.qgis.qgis/issues/428
>> Regards,
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
*Kartoza Cofounder*Tim is a member of the QGIS Project Steering Committee
*T *: +27(0) 87 809 2702 *E *: tim at kartoza.com *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250611/243f4507/attachment.htm>
