[QGIS-Developer] Experimental Qt6 Flatpak build available for Linux/Python devs (for updating plugins)
Raymond Nijssen
r.nijssen at terglobo.nl
Wed Jun 11 21:55:08 PDT 2025
Hi Tim,
The link works for me right now. Maybe it's something on your side?
http://duif.net/qgis-qt6.flatpak
Raymond
On 6/11/25 21:47, Tim Sutton via QGIS-Developer wrote:
> Hi Richard
> Very nice to see this! I tried to download it though and it seems to not
> open the link. I will test on NixOS....
> Regards
> Tim
> On Wed, Jun 11, 2025 at 5:08 PM Germán Carrillo via QGIS-Developer
> <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>>
> wrote:
> Hi,
> Thanks a lot Richard and Aleix, it works like a charm on Ubuntu Noble.
> Regards,
> Germán
> El mié, 11 jun 2025 a las 10:02, Richard Duivenvoorde via QGIS-
> Developer (<qgis-developer at lists.osgeo.org <mailto:qgis-
> developer at lists.osgeo.org>>) escribió:
> Hi,
> Based on the excellent Flatpak work of Aleix Pol (https://
> github.com/flathub/org.qgis.qgis <https://github.com/flathub/
> org.qgis.qgis>), I managed to create a runnable Qt6 build of
> QGIS for Linux's (with flatpak available)
> My idea is that Linux users of distro's without the needed
> dependencies can run QGIS and test/update their Python plugins
> with this build.
> This flatpak build (master) is (thanks to Aleix!) having 3D and
> PDAL/cloudpoint available too.
> Note that this is my first flatpak build, probably things go/are
> wrong, and I'm not sure how to do further/future distribution...
> But for now: to run/try it:
> Download the single-bundle file from
> http://duif.net/qgis-qt6.flatpak <http://duif.net/qgis-qt6.flatpak>
> If you do not have flatpak/flathub available, make sure you do
> by doing the steps at
> https://flatpak.org/setup/ <https://flatpak.org/setup/> for your
> distro, to
> 1) install flatpak and
> 2) make the flathub repo available for needed runtimes and sdk's.
> Now go to the qgis-qt6.flatpak file and INSTALL it:
> flatpak install --runtime --include-sdk qgis-qt6.flatpak
> (this will install the KDE runtime and sdk and then finally the
> qgis-qt6 system wide)
> Then to run it:
> flatpak run org.qgis.qgis
> I hope this is useful for anybody.
> Have to talk to Aleix for more finesses to maybe share this on
> flathub or with his Qt5 build.
> If you want to build it yourself there is some info in: https://
> github.com/flathub/org.qgis.qgis/issues/428 <https://github.com/
> flathub/org.qgis.qgis/issues/428>
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-
> Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-
> developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton
> *Kartoza Cofounder
> *Tim is a member of the QGIS Project Steering Committee*
> *T *: +27(0) 87 809 2702 *E *:**tim at kartoza.com <mailto:tim at kartoza.com>
> *W* : kartoza.com <http://kartoza.com/>
> /This email and any attachments are confidential and intended solely for
> the use of the individual or entity to whom they are addressed. If you /
> /have received this email in error, please notify the sender immediately
> and delete it from your system. Unauthorised use, disclosure, or copying/
> /of the contents is prohibited./
