[QGIS-Developer] Experimental Qt6 Flatpak build available for Linux/Python devs (for updating plugins)
Tim Sutton tim at kartoza.com
Thu Jun 12 14:32:29 PDT 2025
Hi all
Ok this worked
wget -O qgis.flatpak http://duif.net/qgis-qt6.flatpak
Opening the link in my browser not so much...
Thanks
Tim
On Thu, Jun 12, 2025 at 6:16 AM Raymond Nijssen via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi Tim,
> The link works for me right now. Maybe it's something on your side?
> Raymond
> On 6/11/25 21:47, Tim Sutton via QGIS-Developer wrote:
> > Hi Richard
> > Very nice to see this! I tried to download it though and it seems to not
> > open the link. I will test on NixOS....
> > Regards
> > Tim
> > On Wed, Jun 11, 2025 at 5:08 PM Germán Carrillo via QGIS-Developer
> > <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>>
> > wrote:
> >     Hi,
> >     Thanks a lot Richard and Aleix, it works like a charm on Ubuntu
> Noble.
> >     Regards,
> >     Germán
> >     El mié, 11 jun 2025 a las 10:02, Richard Duivenvoorde via QGIS-
> >     Developer (<qgis-developer at lists.osgeo.org <mailto:qgis-
> >     developer at lists.osgeo.org>>) escribió:
> >         Hi,
> >         Based on the excellent Flatpak work of Aleix Pol (https://
> >         github.com/flathub/org.qgis.qgis <https://github.com/flathub/
> >         org.qgis.qgis>), I managed to create a runnable Qt6 build of
> >         QGIS for Linux's (with flatpak available)
> >         My idea is that Linux users of distro's without the needed
> >         dependencies can run QGIS and test/update their Python plugins
> >         with this build.
> >         This flatpak build (master) is (thanks to Aleix!) having 3D and
> >         PDAL/cloudpoint available too.
> >         Note that this is my first flatpak build, probably things go/are
> >         wrong, and I'm not sure how to do further/future distribution...
> >         But for now: to run/try it:
> >         Download the single-bundle file from
> >         http://duif.net/qgis-qt6.flatpak <
> http://duif.net/qgis-qt6.flatpak>
> >         If you do not have flatpak/flathub available, make sure you do
> >         by doing the steps at
> >         https://flatpak.org/setup/ <https://flatpak.org/setup/> for your
> >         distro, to
> >         1) install flatpak and
> >         2) make the flathub repo available for needed runtimes and sdk's.
> >         Now go to the qgis-qt6.flatpak file and INSTALL it:
> >         flatpak install --runtime --include-sdk qgis-qt6.flatpak
> >         (this will install the KDE runtime and sdk and then finally the
> >         qgis-qt6 system wide)
> >         Then to run it:
> >         flatpak run org.qgis.qgis
> >         I hope this is useful for anybody.
> >         Have to talk to Aleix for more finesses to maybe share this on
> >         flathub or with his Qt5 build.
> >         If you want to build it yourself there is some info in: https://
> >         github.com/flathub/org.qgis.qgis/issues/428 <https://github.com/
> >         flathub/org.qgis.qgis/issues/428>
> >         Regards,
> >         _______________________________________________
> >         QGIS-Developer mailing list
> >         QGIS-Developer at lists.osgeo.org <mailto:QGIS-
> >         Developer at lists.osgeo.org>
> >         List info: https://lists.osgeo.org/mailman/listinfo/qgis-
> >         developer <
> https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> >         Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-
> >         developer <
> QGIS-Developer at lists.osgeo.org>
> >     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >     <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> >     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Tim Sutton
> > *Kartoza Cofounder
> > *Tim is a member of the QGIS Project Steering Committee*
> > *T *: +27(0) 87 809 2702 *E *:**tim at kartoza.com <mailto:tim at kartoza.com>
> > *W* : kartoza.com <http://kartoza.com/>
> > /This email and any attachments are confidential and intended solely for
> > the use of the individual or entity to whom they are addressed. If you /
> > /have received this email in error, please notify the sender immediately
> > and delete it from your system. Unauthorised use, disclosure, or copying/
> > /of the contents is prohibited./
Tim Sutton
*Kartoza Cofounder*Tim is a member of the QGIS Project Steering Committee
*T *: +27(0) 87 809 2702          *E *: tim at kartoza.com          *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250612/8e79167c/attachment.htm>
More information about the QGIS-Developer mailing list
