[QGIS-Developer] problem while installing plugin on windows 11
Richard Duivenvoorde
rdmailings at duif.net
Thu Jun 12 05:23:54 PDT 2025
Hi Jacques,
by accident I had something like that recently, and it had to do with the use of - or _ in the zip names...
If I recall myself, we had a plugin call testplugin and I put it in testplugin_0.1.1.zip (or testplugin-0.1.1.zip??).
When you try to install that QGIS could not find the plugin anymore after installation...
So I thought to see if that was a bug, but then found out that if you upload such a plugin to the official repo, the - or _ are stripped from the zip name...
So only because we worked with an internal website as repo (which did not strip that stripes) we have that issue.
Maybe you have something like that too?
Regards,
On 12-06-2025 14:17, Jacques Beilin via QGIS-Developer wrote:
> Dear colleagues,
> I have a problem with some plugins while installing them on windows. It happens on windows 10 or 11. I get an error message saying that the archive seems to be corrupted, whereas the same plugin/archive can be installed on linux.
> I made the test on one of my plugin, IdentifProj. I get an error on windows 11. If I extract the archive on windows and then create a new zip file, I can now install it from this new archive. Did anyone has this kind of problem ?
> Regards,
> Jacques
> ______________________________________________________________________________________
> <https://www.ensg.eu/Collecte-de-la-taxe-d-apprentissage>
> Jacques BEILIN
> Professeur référent en Géodésie, Mathématiques, Métrologie et Topométrie
> Responsable pédagogique de la filière ingénieur 3e année Photogrammétrie, Positionnement, Mesure de Déformations (PPMD)
> École Nationale des Sciences Géographiques
> Cité Descartes, 6-8 Avenue Blaise Pascal, 77420 Champs-sur-Marne
> ign.fr - ensg.eu - geoportail.fr
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
