[QGIS-Developer] problem while installing plugin on windows 11
Jacques Beilin jacques.beilin at ign.fr
Thu Jun 12 05:45:27 PDT 2025
Hi Richard,
It might be that but when I upload the plugin it has no - ou _ in the
name (eg IdentifProj.zip). When I download it (or when Qgis tries to
dowlnoad it) it comes back as IdentifProj-0.5.zip but I can imagine it
is an automatic process.
Jacques
Le 12/06/2025 à 14:23, Richard Duivenvoorde via QGIS-Developer a écrit :
> Hi Jacques,
> by accident I had something like that recently, and it had to do with
> the use of - or _ in the zip names...
> If I recall myself, we had a plugin call testplugin and I put it in
> testplugin_0.1.1.zip (or testplugin-0.1.1.zip??).
> When you try to install that QGIS could not find the plugin anymore
> after installation...
> So I thought to see if that was a bug, but then found out that if you
> upload such a plugin to the official repo, the - or _ are stripped
> from the zip name...
> So only because we worked with an internal website as repo (which did
> not strip that stripes) we have that issue.
> Maybe you have something like that too?
> Regards,
> On 12-06-2025 14:17, Jacques Beilin via QGIS-Developer wrote:
>> Dear colleagues,
>> I have a problem with some plugins while installing them on windows.
>> It happens on windows 10 or 11. I get an error message saying that
>> the archive seems to be corrupted, whereas the same plugin/archive
>> can be installed on linux.
>> I made the test on one of my plugin, IdentifProj. I get an error on
>> windows 11. If I extract the archive on windows and then create a new
>> zip file, I can now install it from this new archive. Did anyone has
>> this kind of problem ?
>> Regards,
>> Jacques
>> ______________________________________________________________________________________
>> <https://www.ensg.eu/Collecte-de-la-taxe-d-apprentissage>
>> Jacques BEILIN
>> Professeur référent en Géodésie, Mathématiques, Métrologie et Topométrie
>> Responsable pédagogique de la filière ingénieur 3e année
>> Photogrammétrie, Positionnement, Mesure de Déformations (PPMD)
>> École Nationale des Sciences Géographiques
>> Cité Descartes, 6-8 Avenue Blaise Pascal, 77420 Champs-sur-Marne
>> ign.fr - ensg.eu - geoportail.fr
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Jacques BEILIN
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250612/a5b63ef3/attachment.htm>
More information about the QGIS-Developer mailing list
