[QGIS-Developer] QGIS version 3.98 instead of 3.99 ?
Richard Duivenvoorde
rdmailings at duif.net
Fri Jun 27 05:59:43 PDT 2025
On 25-06-2025 11:41, Richard Duivenvoorde via QGIS-Developer wrote:
> So maybe best that I make a local edit?
> https://github.com/qgis/QGIS/blob/master/CMakeLists.txt#L64
Argh that did not work, because the QGIS version is used to retrieve the plugins, and between 3.44 and 3.99 there is nothing available :-(
Am I the only one with this issue?
Are others already compiling with Qt6?
Or do others not use any plugins :-(
Regards,
Richard
PS: will downgrade my QT5 build version to 3.44 to at least be able to retrieve/use plugins in that
