[QGIS-Developer] QGIS version 3.98 instead of 3.99 ?
Jacky Volpes
jacky.volpes at oslandia.com
Fri Jun 27 08:49:44 PDT 2025
On Fri Jun 27, 2025 at 2:59 PM CEST, Richard Duivenvoorde via QGIS-Developer wrote:
> On 25-06-2025 11:41, Richard Duivenvoorde via QGIS-Developer wrote:
>> So maybe best that I make a local edit?
>> https://github.com/qgis/QGIS/blob/master/CMakeLists.txt#L64
> Argh that did not work, because the QGIS version is used to retrieve the plugins, and between 3.44 and 3.99 there is nothing available :-(
> Am I the only one with this issue?
Same problem here for me today, tried the same workaround, with the same
conclusion :(
Regards,
Jacky
> Are others already compiling with Qt6?
> Or do others not use any plugins :-(
> Regards,
> Richard
> PS: will downgrade my QT5 build version to 3.44 to at least be able to retrieve/use plugins in that
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Jacky Volpes - Oslandia
Ingénieur développeur SIG
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250627/1b58f5e8/attachment.sig>
