[QGIS-Developer] QGIS version 3.98 instead of 3.99 ?
Rainer Hurling rhurlin at gwdg.de
Sat Jun 28 01:02:11 PDT 2025
Am 27.06.25 um 14:59 schrieb Richard Duivenvoorde via QGIS-Developer:
> On 25-06-2025 11:41, Richard Duivenvoorde via QGIS-Developer wrote:
>> So maybe best that I make a local edit?
>> https://github.com/qgis/QGIS/blob/master/CMakeLists.txt#L64
> Argh that did not work, because the QGIS version is used to retrieve the
> plugins, and between 3.44 and 3.99 there is nothing available :-(
> Am I the only one with this issue?
> Are others already compiling with Qt6?
I am the maintainer of the FreeBSD port of QGIS and have a test version
of 3.99 with Qt6 that runs on FreeBSD. Here, too, all plugins except for
the core plugins have been disabled since 3.99 (including the few that
were previously suitable for Qt6).
Regards,
Rainer
  > Or do others not use any plugins :-(
> Regards,
> Richard
> PS: will downgrade my QT5 build version to 3.44 to at least be able to
> retrieve/use plugins in that
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
