[QGIS-Developer] Test builds for Linux with Qt 6.8?
Tobias Schula geospatial at schula.org
Tue Mar 18 08:04:52 PDT 2025
Hi at all!
Are there test builds of QGIS with Qt 6.8 available for linux? I've asked that
question some time ago already on the user mailing list, but no-one could help
me. I successfully compiled it locally and it's running great. I did it mainly
for the CMYK support, as this greatly simplifies my workflow with printers.
If I find time this week, I wanted to set up a project on the opensuse build
service to compile it and serve binaries for tumbleweed and potentially other
distros.
But before I start the work, are there already binaries available, either as
DEB, RPM or docker images?
If not, is it okay for me to set up a repo and publish it? Will you get
flooded in bug reports (you're already at 4k+) or do you want more testing of
QGIS with Qt 6? Where are good places to publish a link to the repo? Would it
be better to serve the releases or should I trace master?
Best regards
Tobias A Schula
Forestry Expert
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250318/62f53bcf/attachment.sig>
More information about the QGIS-Developer mailing list
