[QGIS-Developer] Test builds for Linux with Qt 6.8?
    Jorge Gustavo Rocha
    jgr at di.uminho.pt
    Wed Mar 19 05:12:28 PDT 2025
Hi Tobias,
Maybe Jürgen can add some valuable insights about this. I would prefer
to see your effort within our infrastructure.
It could be supported by  something like
https://qgis.org/ubuntu-qt6-nightly-release where we could put qt6 based
.deb packages.
I'm compiling locally QGIS with QT6 mostly to test Wayland support and
migrate plugins to QT6.
I can contribute by compiling/packaging QGIS with QT6 on Ubuntu
24.04/24.10, if necessary. The only additional step needed is to compile
QWT 6.2.0, since there is no such package yet.
Regards,
Jorge
On 18/03/25 15:04, Tobias Schula via QGIS-Developer wrote:
> Hi at all!
> Are there test builds of QGIS with Qt 6.8 available for linux? I've asked that
> question some time ago already on the user mailing list, but no-one could help
> me. I successfully compiled it locally and it's running great. I did it mainly
> for the CMYK support, as this greatly simplifies my workflow with printers.
> If I find time this week, I wanted to set up a project on the opensuse build
> service to compile it and serve binaries for tumbleweed and potentially other
> distros.
> But before I start the work, are there already binaries available, either as
> DEB, RPM or docker images?
> If not, is it okay for me to set up a repo and publish it? Will you get
> flooded in bug reports (you're already at 4k+) or do you want more testing of
> QGIS with Qt 6? Where are good places to publish a link to the repo? Would it
> be better to serve the releases or should I trace master?
> Best regards
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
