[QGIS-Developer] locate proj.db used by Qgis from python plugin or script
Even Rouault
even.rouault at spatialys.com
Wed May 14 14:07:40 PDT 2025
>>> from osgeo import osr
>>> osr.GetPROJSearchPaths()
['/home/even/.local/share/proj',
'/home/even/proj/install-proj-master/share/proj',
'/home/even/proj/install-proj-master/share/proj']
and look up for proj.db in one of the above directories. The first one
found will be the one used
Even
Le 14/05/2025 à 22:59, Jacques Beilin via QGIS-Developer a écrit :
> Dear colleagues,
> I have already sent my question on the qgis-user list but someone told me it should be bette to ask on Qgis-dev.
> I am working on the plugin IdentifProj (https://plugins.qgis.org/plugins/IdentifProj/). For the developpement of the plugin I would like to acces to the CRS definition file (proj.db).
> Is there a way to locate the proj.db on the system (and precisely the version which is currentely used by qgis) ? I would like to be able to load it from python to get some informations which are not available from QgsCoordinateReferenceSystem class.
> Best regards,
> Jacques
> ______________________________________________________________________________________
> <https://www.ensg.eu/Collecte-de-la-taxe-d-apprentissage>
> Jacques BEILIN
> Responsable des enseignements en Géodésie, Mathématiques, Métrologie
> et Topométrie
> Responsable pédagogique de la filière ingénieur 3e année
> Photogrammétrie, Positionnement, Mesure de Déformations (PPMD)
> École Nationale des Sciences Géographiques
> Cité Descartes, 6-8 Avenue Blaise Pascal, 77420 Champs-sur-Marne
> ign.fr - ensg.eu - geoportail.fr
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250514/86a6c811/attachment.htm>
