[QGIS-Developer] locate proj.db used by Qgis from python plugin or script
Jacques Beilin jacques.beilin at ign.fr
Thu May 15 01:07:22 PDT 2025
Great. Thanks a lot.
Jacques
Le 14/05/2025 à 23:07, Even Rouault a écrit :
> Hi,
> >>> from osgeo import osr
> >>> osr.GetPROJSearchPaths()
> ['/home/even/.local/share/proj',
> '/home/even/proj/install-proj-master/share/proj',
> '/home/even/proj/install-proj-master/share/proj']
> and look up for proj.db in one of the above directories. The first one
> found will be the one used
> Even
> Le 14/05/2025 à 22:59, Jacques Beilin via QGIS-Developer a écrit :
>> Dear colleagues,
>> I have already sent my question on the qgis-user list but someone told me it should be bette to ask on Qgis-dev.
>> I am working on the plugin IdentifProj (https://plugins.qgis.org/plugins/IdentifProj/). For the developpement of the plugin I would like to acces to the CRS definition file (proj.db).
>> Is there a way to locate the proj.db on the system (and precisely the version which is currentely used by qgis) ? I would like to be able to load it from python to get some informations which are not available from QgsCoordinateReferenceSystem class.
>> Best regards,
>> Jacques
>> ______________________________________________________________________________________
>> <https://www.ensg.eu/Collecte-de-la-taxe-d-apprentissage>
>> Jacques BEILIN
>> Responsable des enseignements en Géodésie, Mathématiques, Métrologie
>> et Topométrie
>> Responsable pédagogique de la filière ingénieur 3e année
>> Photogrammétrie, Positionnement, Mesure de Déformations (PPMD)
>> École Nationale des Sciences Géographiques
>> Cité Descartes, 6-8 Avenue Blaise Pascal, 77420 Champs-sur-Marne
>> ign.fr - ensg.eu - geoportail.fr
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> http://www.spatialys.com
> My software is free, but my time generally not.
Jacques BEILIN
Responsable des enseignements en Géodésie, Mathématiques, Métrologie et
Topométrie
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250515/8c27b673/attachment-0001.htm>
More information about the QGIS-Developer mailing list
