[QGIS-Developer] Python plugin Processing tests using QGIS Docker
Joona Laine
joona.p.laine at gmail.com
Tue Nov 11 02:05:59 PST 2025
Are you using pytest-qgis already in your tests? If you are, just use the
fixture qgis_processing in your tests and testing processing algorithms
should work just fine. Check here for more details on how to easily test
algorithms: https://github.com/GispoCoding/pytest-qgis/issues/27
Cheers,
Joona
ti 11.11.2025 klo 11.09 Sergi Maspons - BGEO via QGIS-Developer (
qgis-developer at lists.osgeo.org) kirjoitti:
> Hi all,
> I'm trying to build some CI tests on GitHub (with pytest) using the
> official qgis/qgis Docker image. Everything works fine except for the parts
> of my plugin that use Processing algorithms. I'd like to run full workflow
> tests, but the processing plugin doesn't seem to be available in the
> container.
> When I try to load it with qgis.utils.loadPlugin('processing') I get this
> error:
> Python error(2): Traceback (most recent call last): File "/usr/share/qgis/python/qgis/utils.py", line 447, in loadPlugin __import__(packageName) File "/usr/share/qgis/python/qgis/utils.py", line 1100, in _import mod = _builtin_import(name, globals, locals, fromlist, level) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ModuleNotFoundError: No module named 'processing'
> Couldn't load plugin 'processing'(1): Couldn't load plugin 'processing'
> I can't find much documentation on how to build CI tests for a QGIS
> plugin, so I've been trying to make it work, but I don't know if I'm doing
> it rightly...
> I've tried installing extra packages (qgis-plugin-grass, grass, saga) in
> the Dockerfile, but it didn't help.
> Here's my *Dockerfile*:
> ARG QGIS_TEST_VERSION=latest
> FROM qgis/qgis:${QGIS_TEST_VERSION}
> RUN apt-get update \
> && apt-get install -y python3-pip qgis-plugin-grass grass saga \
> && rm -rf /var/lib/apt/lists/*
> COPY ./test/requirements.txt /tmp/
> RUN pip3 install --upgrade pip || true
> RUN pip3 install -r /tmp/requirements.txt || pip3 install -r /tmp/requirements.txt --break-system-packages
> ENV LANG=C.UTF-8
> WORKDIR /
> This is my *run-docker-tests.sh*:
> #!/usr/bin/env bash
> set -e
> pushd /usr/src/ibergis_qgis_plugin
> xvfb-run pytest
> popd
> And the relevant part of *GitHub Actions (test.yml)*:
> # Run unit tests
> tests-qgis:
> runs-on: ubuntu-24.04
> strategy:
> fail-fast: false
> matrix:
> qgis_version: [latest, ltr, stable]
> env:
> QGIS_TEST_VERSION: ${{ matrix.qgis_version }}
> steps:
> - name: Checkout
> uses: actions/checkout at v4
> with:
> submodules: recursive
> - name: Test
> run: |
> chmod +x .docker/run-docker-tests.sh
> docker compose -f .docker/docker-compose.yml run qgis /usr/src/ibergis_qgis_plugin/.docker/run-docker-tests.sh
> I haven't found much documentation on running QGIS plugin tests in CI
> environments, so I might be missing something obvious.
> If anyone has experience running tests that use Processing algorithms
> inside Docker, I'd really appreciate some guidance.
> Thanks in advance!
> *Sergi Maspons "Maspi"*
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20251111/0be6e31f/attachment.htm>
