[QGIS-Developer] Python plugin Processing tests using QGIS Docker
Germán Carrillo
carrillo.german at gmail.com
Tue Nov 11 06:18:51 PST 2025
Hi Sergi,
I think I faced the same issue earlier this year.
Have a look at our test.yaml file [1], we needed to pass PYTHONPATH to the
docker run command.
Hope that helps.
Regards,
Germán
[1]
https://github.com/opengisch/pzp/blob/f951fa3fa4ae3662d01d733ea6a32a4d41acedc6/.github/workflows/test.yml#L33
El mar, 11 nov 2025 a las 5:06, Joona Laine via QGIS-Developer (<
qgis-developer at lists.osgeo.org>) escribió:
> Hi,
> Are you using pytest-qgis already in your tests? If you are, just use the
> fixture qgis_processing in your tests and testing processing algorithms
> should work just fine. Check here for more details on how to easily test
> algorithms: https://github.com/GispoCoding/pytest-qgis/issues/27
> Cheers,
> Joona
> ti 11.11.2025 klo 11.09 Sergi Maspons - BGEO via QGIS-Developer (
> qgis-developer at lists.osgeo.org) kirjoitti:
>> Hi all,
>> I'm trying to build some CI tests on GitHub (with pytest) using the
>> official qgis/qgis Docker image. Everything works fine except for the parts
>> of my plugin that use Processing algorithms. I'd like to run full workflow
>> tests, but the processing plugin doesn't seem to be available in the
>> container.
>> When I try to load it with qgis.utils.loadPlugin('processing') I get this
>> error:
>> Python error(2): Traceback (most recent call last): File "/usr/share/qgis/python/qgis/utils.py", line 447, in loadPlugin __import__(packageName) File "/usr/share/qgis/python/qgis/utils.py", line 1100, in _import mod = _builtin_import(name, globals, locals, fromlist, level) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ModuleNotFoundError: No module named 'processing'
>> Couldn't load plugin 'processing'(1): Couldn't load plugin 'processing'
>> I can't find much documentation on how to build CI tests for a QGIS
>> plugin, so I've been trying to make it work, but I don't know if I'm doing
>> it rightly...
>> I've tried installing extra packages (qgis-plugin-grass, grass, saga) in
>> the Dockerfile, but it didn't help.
>> Here's my *Dockerfile*:
>> ARG QGIS_TEST_VERSION=latest
>> FROM qgis/qgis:${QGIS_TEST_VERSION}
>> RUN apt-get update \
>> && apt-get install -y python3-pip qgis-plugin-grass grass saga \
>> && rm -rf /var/lib/apt/lists/*
>> COPY ./test/requirements.txt /tmp/
>> RUN pip3 install --upgrade pip || true
>> RUN pip3 install -r /tmp/requirements.txt || pip3 install -r /tmp/requirements.txt --break-system-packages
>> ENV LANG=C.UTF-8
>> WORKDIR /
>> This is my *run-docker-tests.sh*:
>> #!/usr/bin/env bash
>> set -e
>> pushd /usr/src/ibergis_qgis_plugin
>> xvfb-run pytest
>> popd
>> And the relevant part of *GitHub Actions (test.yml)*:
>> # Run unit tests
>> tests-qgis:
>> runs-on: ubuntu-24.04
>> strategy:
>> fail-fast: false
>> matrix:
>> qgis_version: [latest, ltr, stable]
>> env:
>> QGIS_TEST_VERSION: ${{ matrix.qgis_version }}
>> steps:
>> - name: Checkout
>> uses: actions/checkout at v4
>> with:
>> submodules: recursive
>> - name: Test
>> run: |
>> chmod +x .docker/run-docker-tests.sh
>> docker compose -f .docker/docker-compose.yml run qgis /usr/src/ibergis_qgis_plugin/.docker/run-docker-tests.sh
>> I haven't found much documentation on running QGIS plugin tests in CI
>> environments, so I might be missing something obvious.
>> If anyone has experience running tests that use Processing algorithms
>> inside Docker, I'd really appreciate some guidance.
>> Thanks in advance!
>> *Sergi Maspons "Maspi"*
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20251111/da8ff5f0/attachment.htm>
