[QGIS-Developer] Remove "Polygons must follow boundaries of layer ..." check in Geometry checker plugin?
DelazJ delazj at gmail.com
Fri Nov 21 01:17:58 PST 2025
Hi devs,
I didn't get any reply so I wonder if it is because nobody knows, nobody
cares, or something else...
Other than the concern of "adding/keeping a broken tool" in QGIS, we have a
PR in the docs we don't really know how to finalize, so a feedback would be
appreciated.
Thanks.
Regards,
Harrissou (for the docs team)
Le mar. 28 oct. 2025 à 10:38, DelazJ <delazj at gmail.com> a écrit :
> Hi Devs,
> In the "Geometry checker" core plugin, there is that option
> called "Polygons must follow boundaries of layer ...", of which a
> Processing alg "Polygons exceeding boundaries" was recently created.
> While testing the algorithm in order to properly document it, we came
> across weird results (also output by the geometry checker) that we are
> unable to explain/understand their coherence.
> Issues and discussion are availabel at
> https://github.com/qgis/QGIS/issues/63454 and
> https://github.com/qgis/QGIS-Documentation/pull/10314#issuecomment-3425649278
> 1/ Does anyone *KNOW* how this option is really supposed to check? and
> understand the logic behind the output?
> 2/ If there is agreement that this tool does not adress any real use case,
> is it something we want to keep in QGIS (in this state)?
> Looking forward to your replies.
> Regards,
> Harrissou
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20251121/cffdef77/attachment.htm>
More information about the QGIS-Developer mailing list
