[QGIS-Developer] numpy version 2
Hernán De Angelis variablestarlight at gmail.com
Wed Oct 8 05:18:24 PDT 2025
If it helps, I have been compiling the master branch regularly for sometime
using numpy > 2 (currently 2.3.3, with python 3.13.7 on openSUSE
Tumbleweed) without any apparent issue or malfunction that I have been
aware of. I am not an expert on these matters though, and there may be
issues that have escaped my attention.
On Wed, Oct 8, 2025 at 1:54 PM Greg Troxel via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Fredrik Lindberg via QGIS-Developer <qgis-developer at lists.osgeo.org>
> writes:
> > Are there any plans to implement numpy v2 in any near future as 1.26
> > is becoming rather old at this stage?
> Can you summarize what you found out when reading the build
> documentation about whether the qgis master branch can be built against
> numpy2, and what happened when you tried to build against it?
> From numpy's release dates it looks like it is only roughly a year since
> it has been reasonable to use numpy in production.   It's an interesting
> question how the numpy-using community views it, in terms of which is
> the first 2.x to be safe to use in production.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20251008/7a2d6ccc/attachment.htm>
More information about the QGIS-Developer mailing list
