[QGIS-Developer] numpy version 2
Fredrik Lindberg
fredrikl at gvc.gu.se
Wed Oct 8 07:18:49 PDT 2025
I did not try to build nor have read the documentation, I have only started to experience conflicts in some of my plugins where third-party packages, started to require np>=2...
Från: QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> för Greg Troxel via QGIS-Developer <qgis-developer at lists.osgeo.org>
Skickat: den 8 oktober 2025 13:54
Till: Fredrik Lindberg via QGIS-Developer <qgis-developer at lists.osgeo.org>
Ämne: Re: [QGIS-Developer] numpy version 2
writes:
> Are there any plans to implement numpy v2 in any near future as 1.26
> is becoming rather old at this stage?
Can you summarize what you found out when reading the build
documentation about whether the qgis master branch can be built against
numpy2, and what happened when you tried to build against it?
>From numpy's release dates it looks like it is only roughly a year since
it has been reasonable to use numpy in production. It's an interesting
question how the numpy-using community views it, in terms of which is
the first 2.x to be safe to use in production.
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20251008/93b365cc/attachment.htm>
