[QGIS-Developer] numpy version 2
Brian M Hamlin
maplabs at light42.com
Wed Oct 8 13:58:57 PDT 2025
for the python3 stack (large, complex) #osgeolive has not made the
switch to Numpy v2+
https://trac.osgeo.org/osgeolive/wiki/noblenightly57
--Brian M Hamlin / MAPLABS / #osgeolive PSC
On 10/8/25 04:54, Greg Troxel via QGIS-Developer wrote:
> Fredrik Lindberg via QGIS-Developer <qgis-developer at lists.osgeo.org>
> writes:
>> Are there any plans to implement numpy v2 in any near future as 1.26
>> is becoming rather old at this stage?
> Can you summarize what you found out when reading the build
> documentation about whether the qgis master branch can be built against
> numpy2, and what happened when you tried to build against it?
> From numpy's release dates it looks like it is only roughly a year since
> it has been reasonable to use numpy in production. It's an interesting
> question how the numpy-using community views it, in terms of which is
> the first 2.x to be safe to use in production.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
