[QGIS-Developer] Remove "Polygons must follow boundaries of layer ..." check in Geometry checker plugin?
DelazJ delazj at gmail.com
Tue Oct 28 02:38:46 PDT 2025
Hi Devs,
In the "Geometry checker" core plugin, there is that option
called "Polygons must follow boundaries of layer ...", of which a
Processing alg "Polygons exceeding boundaries" was recently created.
While testing the algorithm in order to properly document it, we came
across weird results (also output by the geometry checker) that we are
unable to explain/understand their coherence.
Issues and discussion are availabel at
https://github.com/qgis/QGIS/issues/63454 and
https://github.com/qgis/QGIS-Documentation/pull/10314#issuecomment-3425649278
1/ Does anyone *KNOW* how this option is really supposed to check? and
understand the logic behind the output?
2/ If there is agreement that this tool does not adress any real use case,
is it something we want to keep in QGIS (in this state)?
Looking forward to your replies.
Regards,
Harrissou
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20251028/5f25ad04/attachment-0001.htm>
More information about the QGIS-Developer mailing list
