[QGIS-Developer] Emergency – Accidentally deleted plugin from the QGIS plugin repository, can it be restored?
Lova Andriarimalala
lova at kartoza.com
Wed Oct 29 05:48:28 PDT 2025
Dear Mike,
Deleting a plugin is a permanent action that cannot be undone, as stated on
the plugin deletion confirmation page. Indeed, from the administration
side, it would probably require patching the live database with your plugin
(including all relations such as versions, feedback...) from the previous
backup, which is a complex and risky task.
I would suggest re-uploading the plugin as a new one (without changing the
name), with all versions if needed.
Best regards,
Lova Andriarimalala
*QGIS Full Stack Developer *
*T *: +27(0) 87 809 2702 *E *: lova at kartoza.com *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Wed, 29 Oct 2025 at 14:14, Elstermann, Mike via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hello everyone,
> I accidentally deleted my plugin ‘GeoBasis_Loader’; I actually only wanted
> to delete one version. Is there any way to restore it? If so, who can I
> contact?
> Thanks & best regards, Mike Elstermann
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20251029/8145678f/attachment.htm>
