[QGIS-Developer] [EXT] Emergency – Accidentally deleted plugin from the QGIS plugin repository, can it be restored?[Achtung - Absenderprüfung fehlgeschlagen]
Elstermann, Mike
Mike.Elstermann at itc-halle.de
Wed Oct 29 08:01:24 PDT 2025
OMG, THANKS!
Zimbogisgeek suggested I try Admire, saying he might be able to help. I'm praying to all the GIS gods that it works ;-)
Admire, are you reading this and can you help?
Best regards, Mike Elstermann
Am 29.10.2025 um 13:48 schrieb Lova Andriarimalala <lova at kartoza.com>:
ACHTUNG: Diese E-Mail stammt von einem externen Absender (außerhalb der SWH-Gruppe). Bitte höchste Vorsicht mit Dateianhängen und Hyperlinks! Im Zweifelsfall wird empfohlen, den Absender (z.B. per Telefon) zu kontaktieren und die Echtheit der E-Mail zu prüfen.
Dear Mike,
Deleting a plugin is a permanent action that cannot be undone, as stated on the plugin deletion confirmation page. Indeed, from the administration side, it would probably require patching the live database with your plugin (including all relations such as versions, feedback...) from the previous backup, which is a complex and risky task.
I would suggest re-uploading the plugin as a new one (without changing the name), with all versions if needed.
Best regards,
Lova Andriarimalala
QGIS Full Stack Developer
T : +27(0) 87 809 2702 E : lova at kartoza.com<mailto:lova at kartoza.com> W : kartoza.com<http://kartoza.com/>
[https://kartoza.com/files/KartozaEmailSignature.gif]
This email and any attachments are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you
have received this email in error, please notify the sender immediately and delete it from your system. Unauthorised use, disclosure, or copying
of the contents is prohibited.
On Wed, 29 Oct 2025 at 14:14, Elstermann, Mike via QGIS-Developer <qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>> wrote:
Hello everyone,
I accidentally deleted my plugin ‘GeoBasis_Loader’; I actually only wanted to delete one version. Is there any way to restore it? If so, who can I contact?
Thanks & best regards, Mike Elstermann
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org<mailto:QGIS-Developer at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20251029/626f0cd6/attachment-0001.htm>
