[QGIS-Developer] Please treat master as "frozen" right now
Alessandro Pasotti apasotti at gmail.com
Thu Sep 18 08:21:58 PDT 2025
Hi Nyall,
I'm on 25.04 and building with QT6 and a locally built libspatialindex but
I cannot reproduce the issue on my local build, I tried to disable the
latest sever API test I have recently added (the one that reloads the
libraries to test for a different root path set through an env var) because
it was the number one suspect but it didn't help, it seems to me that a few
server tests are randomly failing (they are different any time I re-run the
failing job).
See
https://cdash.orfeo-toolbox.org/index.php?project=QGIS&date=2025-09-18&filtercount=1&showfilters=1&field1=buildname&compare1=63&value1=PR63250
I am trying to reproduce a server crash by running the tests locally but I
haven't been lucky so far.
On Thu, Sep 18, 2025 at 7:06 AM Alessandro Pasotti <apasotti at gmail.com>
wrote:
> Hi,
> I will have a look today.
> Alessandro Pasotti
> QCooperative:  www.qcooperative.net
> ItOpen:   www.itopen.it
> Il gio 18 set 2025, 02:56 Nyall Dawson via QGIS-Developer <
> qgis-developer at lists.osgeo.org> ha scritto:
>> On Tue, 16 Sept 2025 at 14:02, Nyall Dawson <nyall.dawson at gmail.com>
>> wrote:
>>> Hi list,
>>> While the CI is in a broken state (caused by ubuntu 24.10 going EOL),
>>> please don't merge ANYTHING! Our focus right now should ONLY be on fixing
>>> CI and getting the green ticks back again.
>> Ok, thanks to hard work by Mathieu, we're nearly back in the green.
>> Can someone with server experience please look at the Server API test,
>> which is failing ~50% of the time now. This is reproducible on Ubuntu 25.04
>> local builds too.
>> Nyall
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250918/292e30b5/attachment.htm>
More information about the QGIS-Developer mailing list
