[QGIS-Developer] ETRS89-XXX fallouts (aka PROJ 9.8.0 related issues)
Even Rouault even.rouault at spatialys.com
Fri Apr 3 11:03:53 PDT 2026
Not a QGIS bug, but just to make you aware that we (PROJ) are seeing
several reports from European users that are facing issues with the
deployment of the new ETRS89-XXX datums in the EPSG database that is
provided with PROJ 9.8.0, instead of previous use of generic ETRS89
datum ensemble, in particular for datum transformations between those
new datums and existing national datums.
https://github.com/OSGeo/PROJ/pull/4736 has a few examples of such
issues. If there are other cases, please report (as PROJ tickets) so we
can report back to EPSG.
It could be wise for OSGeo4W installers to downgrade to 9.7.1 in the
mean time, especially for QGIS 3.44 build (didn't check which PROJ
version it used)
Even
http://www.spatialys.com
More information about the QGIS-Developer mailing list
