[QGIS-Developer] Plugin falsely blocked by Bandit Security Analysis
Jürgen E. Fischer
jef at norbit.de
Sun Aug 9 09:27:42 PDT 2026
Hi Johannes,
On Sun, 09. Aug 2026 at 05:08:17 +0000, Johannes Jenkner via QGIS-Developer wrote:
> Is the there anything I can do to unblock the plugin version and
> simultaneously keep the random numbers as essential part of my plugin
> algorithm?
You can add "# nosec" to the "offending" lines (and you should also move
the replacement arguments outside of the tr call).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany Matrix: @jef:osgeo.org
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260809/be78c977/attachment.sig>
