[QGIS-Developer] Advice on generating QGIS QML styles using AI
Nyall Dawson nyall.dawson at gmail.com
Thu Aug 27 17:17:06 PDT 2026
On Fri, 28 Aug 2026 at 10:06, Denis Rykov via QGIS-Developer
<qgis-developer at lists.osgeo.org> wrote:
> Hi,
> I’m currently exploring how to use an LLM/AI to generate valid QGIS .qml styles from natural-language prompts. One difficulty I’ve encountered is that, as far as I know, there is no formal or exhaustive schema for the QML format describing both the XML hierarchy and the semantics of all elements, attributes, renderers, symbol layers, labeling settings, etc. I’m currently investigating whether PyQGIS can be used to discover this information programmatically. I can create QGIS objects, serialize them using QGIS itself, and recursively inspect the resulting DOM. This provides information about the actual XML hierarchy, attributes, default values, and property definitions. Before going further, however, I wanted to ask the QGIS developers whether there is a more canonical approach.
> In particular:
> Is there an existing source of truth for the QML structure/schema that I may have missed?
No -- it's considered an internal private detail only, and changes
many times throughout the release cycle (while maintaining
compatibility with existing QML files!).
> Is the QML format intentionally undocumented/non-schema-based,
Yes
> with the QGIS C++ serialization code effectively serving as the authoritative specification?
Kind of -- but again, it's intentionally NOT a fixed specification at
all, but just a reflection of what QGIS internal classes need to store
for any particular release.
> Would using PyQGIS to instantiate the different renderers, symbol layers, labeling configurations, etc., and then inspecting their QDomDocument serialization be a reasonable way to generate a machine-readable schema?
Possibly, yes, if you're just interested in generating XML that QGIS
will consume. If you're attempting to READ xml that qgis produces then
the recommended approach is always to just use QGIS api directly to
read this, and then extract properties from the resulting symbols
using the stable API.
Nyall
> Are there particular QGIS APIs or parts of the source tree that you would recommend for this purpose?
> I’d appreciate any advice on whether this is the right direction, or whether there is a more appropriate way to obtain or generate such a schema from QGIS itself.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
