[QGIS-Developer] Advice on generating QGIS QML styles using AI
Tim Sutton tim at kartoza.com
Fri Aug 28 14:36:51 PDT 2026
Hi Denis
You may also want to take a peek at the GeoStyler (https://geostyler.org/)
project which attempts to be a babel fish for different style formats,
including QGIS QML. I am guessing they have some kind of conceptual
mapping, at least between the shared concepts within the various formats
they support.
Regards,
Tim
On Fri, Aug 28, 2026 at 1:17 AM Nyall Dawson via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> On Fri, 28 Aug 2026 at 10:06, Denis Rykov via QGIS-Developer
> <qgis-developer at lists.osgeo.org> wrote:
> > Hi,
> > I’m currently exploring how to use an LLM/AI to generate valid QGIS .qml
> styles from natural-language prompts. One difficulty I’ve encountered is
> that, as far as I know, there is no formal or exhaustive schema for the QML
> format describing both the XML hierarchy and the semantics of all elements,
> attributes, renderers, symbol layers, labeling settings, etc. I’m currently
> investigating whether PyQGIS can be used to discover this information
> programmatically. I can create QGIS objects, serialize them using QGIS
> itself, and recursively inspect the resulting DOM. This provides
> information about the actual XML hierarchy, attributes, default values, and
> property definitions. Before going further, however, I wanted to ask the
> QGIS developers whether there is a more canonical approach.
> > In particular:
> > Is there an existing source of truth for the QML structure/schema that I
> may have missed?
> No -- it's considered an internal private detail only, and changes
> many times throughout the release cycle (while maintaining
> compatibility with existing QML files!).
> > Is the QML format intentionally undocumented/non-schema-based,
> Yes
> > with the QGIS C++ serialization code effectively serving as the
> authoritative specification?
> Kind of -- but again, it's intentionally NOT a fixed specification at
> all, but just a reflection of what QGIS internal classes need to store
> for any particular release.
> > Would using PyQGIS to instantiate the different renderers, symbol
> layers, labeling configurations, etc., and then inspecting their
> QDomDocument serialization be a reasonable way to generate a
> machine-readable schema?
> Possibly, yes, if you're just interested in generating XML that QGIS
> will consume. If you're attempting to READ xml that qgis produces then
> the recommended approach is always to just use QGIS api directly to
> read this, and then extract properties from the resulting symbols
> using the stable API.
> Nyall
> > Are there particular QGIS APIs or parts of the source tree that you
> would recommend for this purpose?
> > I’d appreciate any advice on whether this is the right direction, or
> whether there is a more appropriate way to obtain or generate such a schema
> from QGIS itself.
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
*Kartoza Cofounder*Tim is a member of the QGIS Project Steering Committee
*E *: tim at kartoza.com          *W* : kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260828/1607fd4f/attachment.htm>
More information about the QGIS-Developer mailing list
