[QGIS-Developer] SAP HANA on MacOS
Even Rouault
even.rouault at spatialys.com
Thu Feb 19 16:37:28 PST 2026
Le 19/02/2026 à 18:04, Schimmel, Florian via QGIS-Developer a écrit :
> Hey Matthias,
> thank you for the reply, I like the idea and tried to implement it. I
> had to work into vcpkg and solve a few issues on the way, that took a
> while, but I have a working port now. While checking if it is possible
> to integrate the port in the QGIS build I noticed that there are
> custom ports in the repository. Since odbccpp is not broadly used,
> there is probably no application for a vcpkg port outside of QGIS, so
> would you mind if we add the port directly to the QGIS repository?
The GDAL HANA driver depends on odbccpp too, so for GDAL vcpkg users,
having a standalone port could make sense
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260220/55efa1b0/attachment.htm>
