[QGIS-Developer] SAP HANA on MacOS
Schimmel, Florian florian.schimmel at sap.com
Fri Feb 20 06:47:34 PST 2026
Hey Even,
Thanks for the hint, that makes sense. I will add it to the vcpkg repo and note this thread again after it is merged and the QGIS change is pushed.
Best regards
Florian
Date: Friday, 20. February 2026 at 01:37
To: Schimmel, Florian <florian.schimmel at sap.com>, Matthias Kuhn <matthias at opengis.ch>
Cc: qgis-developer at lists.osgeo.org <qgis-developer at lists.osgeo.org>
Subject: Re: [QGIS-Developer] SAP HANA on MacOS
You don't often get email from even.rouault at spatialys.com. Learn why this is important<https://aka.ms/LearnAboutSenderIdentification>
Le 19/02/2026 à 18:04, Schimmel, Florian via QGIS-Developer a écrit :
Hey Matthias,
thank you for the reply, I like the idea and tried to implement it. I had to work into vcpkg and solve a few issues on the way, that took a while, but I have a working port now. While checking if it is possible to integrate the port in the QGIS build I noticed that there are custom ports in the repository. Since odbccpp is not broadly used, there is probably no application for a vcpkg port outside of QGIS, so would you mind if we add the port directly to the QGIS repository?
The GDAL HANA driver depends on odbccpp too, so for GDAL vcpkg users, having a standalone port could make sense
http://www.spatialys.com<http://www.spatialys.com/>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260220/13b77eae/attachment-0001.htm>
More information about the QGIS-Developer mailing list
