[QGIS-Developer] SAGA GIS plugin maintenance
Sebastian Gutwein
bas at rdgland.com
Wed Jul 22 06:25:36 PDT 2026
Hi all,
I'm not a trained programmer but I use SAGA in QGIS frequently and teach
with it so am interested in having the plugin in the repository.
To that end I have forked the SAGA Next Gen repository and made a few
changes to make it compatible with QGIS 4.x. and am planning on uploading
to the official QGIS repository.
I talked to Nyall and he was supportive of this. I don't know that I will
be able to fully maintain the functionality if SAGA continues to change
things as is described in these threads.
However, it currently functions for my needs and I assume for others as
well. If anyone else has other plans for the plugin I am happy to pass it
off to them.
The repository is here -
https://github.com/baswein/qgis-processing-saga-nextgen .
Thank everyone at QGIS and SAGA for all of their contributions over the
years to open source GIS.
-Bas
On Thu, May 21, 2026 at 8:16 AM Stefano Campus via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> First of all, thank you all for your feedback.
> It is clear that the problem is not (solely) the SAGA plugin, but rather a
> perspective on the sustainability of open-source projects, which, I
> imagine, Nyall has rightly raised.
> To avoid any misunderstanding and in response to Greg’s comments, in this
> context I am simply a user who used to use SAGA very frequently some time
> ago; as the features of QGIS/ Processing have improved and expanded, I
> hardly use it anymore, except for rasterisation, which allows complete
> control over the rasterisation values when, for example, I have overlapping
> points, and SAGA allows you to choose whether to assign the minimum,
> average, maximum, sum, etc., to the raster cell – a function that GDAL does
> not have.
> However, I reiterate that I consider Nyall’s decision to be a
> ‘provocation’ (in a positive sense, let’s be clear) to draw attention to
> sustainability.
> Jurgen has stated the difficulty in keeping up with SAGA’s developments,
> which are often unannounced, and attempts at structured collaboration –
> correct me if I’m wrong – with SAGA’s maintainers have not yielded good
> results.
> So, returning to the specific case, I believe the solutions could be:
> 1) SAGA is no longer a third-party module provider, as it no longer
> develops or maintains any plugins;
> 2) specific voluntary contributions are found, either short-term or
> long-term
> tertium non datur!
> Regards
> s.
> Il giorno gio 21 mag 2026 alle ore 13:41 Stefano Campus <skampus at gmail.com>
> ha scritto:
>> If I’m not mistaken, over the years, the SAGA maintainers haven’t paid
>> much attention to integration with QGIS; proof of this is that they’ve
>> changed the structure of the modules, renamed them, and so on, without
>> making any announcement or contacting the QGIS maintainers in any way
>> Il giorno gio 21 mag 2026 alle ore 11:53 <
>> qgis-developer-request at lists.osgeo.org> ha scritto:
>>> *Bas Couwenberg* sebastic at xs4all.nl
>>> <qgis-developer%40lists.osgeo.org?Subject=Re%3A%20%5BQGIS-Developer%5D%20SAGA%20GIS%20plugin%20maintenance&In-Reply-To=%3Ce4d5973f-3ab3-4993-8e73-8e3a8a6ec88f%40xs4all.nl%3E>
>>> *Thu May 21 03:40:36 PDT 2026*
>>> - Previous message (by thread): [QGIS-Developer] SAGA GIS plugin
>>> maintenance
>>> <https://lists.osgeo.org/pipermail/qgis-developer/2026-May/068253.html>
>>> - *Messages sorted by:* [ date ]
>>> <https://lists.osgeo.org/pipermail/qgis-developer/2026-May/date.html#68254>
>>> [ thread ]
>>> <https://lists.osgeo.org/pipermail/qgis-developer/2026-May/thread.html#68254>
>>> [ subject ]
>>> <https://lists.osgeo.org/pipermail/qgis-developer/2026-May/subject.html#68254>
>>> [ author ]
>>> <https://lists.osgeo.org/pipermail/qgis-developer/2026-May/author.html#68254>
>>> On 5/21/26 11:53 AM, Stefano Campus via QGIS-Developer wrote:
>>> >* Do you think it would be a good idea to propose to the Steering Group that
>>> *>* its maintenance be taken on directly by the QGIS.org Foundation and that a
>>> *>* certain sum (1000–2000 euros?) be set aside in the annual budget for its
>>> *>* maintenance?
>>> No, I think it makes more sense for the SAGA developers to commit to maintaining the QGIS plugin which will likely motivate them to stabilize their interface.
>>> Kind Regards,
>>> Bas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Sebastian "Bas* " Gutwein
*rhymes with Josh
Regenerative Design Group
1 Chevalier Ave
Greenfield, Ma 01301
Web: regenerativedesigngroup.com
(631) 241-1018
*Look close, think big, make change. *
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260722/a125571a/attachment-0001.htm>
