[QGIS-Developer] SAGA GIS plugin maintenance
Sebastian Gutwein bas at rdgland.com
Wed Jul 22 06:37:13 PDT 2026
Hi Rainer,
Thanks for working on this and all of your work on SAGA. I am
considering taking over the plugin because I use and teach with SAGA in
QGIS and it works for me in the current state.
If I wanted to ask questions or get updates on potentially breaking changes
would I do that on the sourceforge forum?
I did try using PySAGA found it to be much slower but I don't think I was
using the pre file conversion the the current plugin uses or I wasn't
batching my calls correctly so I would be interested to find out the best
way to set this up in the future.
the repository is here-
https://github.com/baswein/qgis-processing-saga-nextgen
Thanks again.
-Bas
On Mon, Jun 1, 2026 at 2:24 PM Rainer Hurling via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Dear QGIS developers,
> I had promised to get back to you after a meeting with our SAGA
> dev-team. I would like to do so here.
> Am 25.05.26 um 18:25 schrieb Rainer Hurling via QGIS-Developer:
> > Dear QGIS devs,
> > I am writing to you on behalf of the small group of SAGA GIS developers.
> > This thread has raised several points and perspectives that are of great
> > interest to us, and we would like to share the SAGA team’s perspective
> > on them.
> > However, before we contribute here, we would like to discuss this at our
> > regular developer meeting next Friday (May 29). We have already added
> > the topic to the agenda :)
> > After that, we will post here in the thread and try to outline our
> options.
> > @Nyall: Could you please make the “SAGA Processing Nextgen” plugin,
> > which is currently set to “private”, public again for a while? I’d like
> > to fork it, thanks!
> > Best wishes,
> > Rainer  (FreeBSD ports committer)
> Since this thread concerns the “Processing Saga NextGen Provider”
> plugin, it should be noted up front that this is a QGIS plugin developed
> by a QGIS developer. The SAGA team was never involved in its development.
> We discussed the following in our SAGA meeting:
> - Basically, we (at SAGA) have no interest in maintaining the existing
> plugin, further developing it, or even developing a new, more
> comprehensive SAGA plugin for QGIS.
> - If there is interest within the QGIS community in developing a more
> comprehensive plugin for integrating SAGA, we recommend not building on
> the SAGA command-line tool ‘saga_cmd’ but instead using PySAGA (or the
> C++ API). This would allow the respective functionalities and parameters
> of all non-interactive SAGA tools to be used directly and
> comprehensively. It would also allow in-memory passing of datasets, i.e.
> no temporary files would need to be written.
> - Converting all data types on a 1:1 basis is likely to remain a
> challenge. There are data types in SAGA that do not exist in QGIS.
> - Overall, we are positive about the integration of SAGA in QGIS, but we
> think such a project needs a sustainable approach. If the QGIS community
> wishes to improve or update the integration of SAGA with QGIS, the SAGA
> team is happy to provide information and advice if requested. We would
> also be happy to establish or point to communication channels so that
> the community can stay informed about new SAGA versions and upcoming
> changes.
> A personal note on the “Processing Saga NextGen Provider” plugin: Since
> I am the maintainer (rhurlin at FreeBSD.org) of both the SAGA GIS port [1]
> and the QGIS port [2] for FreeBSD, I decided out of curiosity to copy
> the SAGA NextGen Provider plugin from a QGIS 3 installation to a QGIS 4
> installation and then run the ‘scan_qt6_compat’ v1.2 plugin by François
> Thevand on the SAGA plugin in QGIS 4. This allowed the SAGA plugin to be
> converted to Qt6 and QGIS 4 fully automatically and seemingly without
> errors, and it can now be used in QGIS 4 as usual. Perhaps this is a way
> for the QGIS community to continue working with this plugin for the time
> being?
> [1] https://www.freshports.org/math/saga
> [2] https://www.freshports.org/graphics/qgis and
>      https://www.freshports.org/graphics/qgis-ltr
> Best regards,
> Rainer
> > Am 22.05.26 um 01:55 schrieb Nyall Dawson via QGIS-Developer:
> >> On Thu, 21 May 2026 at 19:53, Stefano Campus via QGIS-Developer <qgis-
> >> developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>>
> wrote:
> >>  > I’m writing to the dev list because I think this issue is of
> interest.
> >>  > For the past few days, the SAGA Next plugin—which allows you to use
> >> SAGA GIS modules within QGIS Processing—has been unavailable.
> >> Thanks for kicking off this discussion -- I've been waiting for
> >> someone to raise it 😁🍿
> >> To explain the situation:
> >> I've been "maintaining" that plugin for years. That's an over-
> >> exaggeration... it hasn't received any love from me beyond reviewing a
> >> pull request once every couple of years. I initially forked it (SAGA
> >> NextGen) from the core SAGA plugin back in 2019 to help solve issues
> >> with SAGA availability of LTR releases and broken stable API. Then in
> >> 2019 https://github.com/qgis/QGIS-Enhancement-Proposals/issues/230
> >> <https://github.com/qgis/QGIS-Enhancement-Proposals/issues/230>
> >> followed, when the built-in SAGA plugin was removed and it went from
> >> being an out-of-the-box, "qgis.org <http://qgis.org> maintained"
> >> plugin to relying on the third party SAGA NextGen "community
> >> maintained" plugin. That's 100% because it was concluded by all the
> >> developers responsible for that code that it wasn't up to the quality
> >> standards of the rest of QGIS.
> >> It was always a fragile mess of a plugin. Part of that was because of
> >> the difficulties associated with SAGA versioning, part of that was
> >> because it was initially forked from old python code that no-one had
> >> ever modernised. To say it was held together with chewing gum would be
> >> a lie... it was held together with some soggy wet toilet paper at
> >> best! 😆 This really bugged me. I'd see constant user frustration
> >> because it never worked well, and IMO this user frustration was
> >> harming the reputation of QGIS itself. It didn't help that I'd keep
> >> reading blogs/guides/tutorials where people were recommending using it
> >> for operations where QGIS native tools are SOOOO much better (eg
> >> vector operations like buffering).
> >> It was never my desire to become the maintainer of the plugin and put
> >> in the work required to bring it up to the quality standard I hold to,
> >> rather, I offered it on an initially voluntary basis to fix immediate
> >> issues I saw users were experiencing and with the hope that making it
> >> a third party plugin would help grow a healthy community that would
> >> take it over.
> >> That never happened... Instead it was just another burden that I
> >> carried for everyone, with the associated lack of thanks and lack of
> >> any recognition beyond angry emails when it didn't work. 🤷. Ah well,
> >> that's just life as a QGIS developer, we all deal with that, and I'm
> >> thick- skinned enough to handle it!
> >> At least, I thought so. Then the AI apocalypse hit in 2026.
> >> As a response to my frustration with the lack of support the user
> >> community is giving to open-source developers during this INCREDIBLY
> >> challenging time, I decided to close off a bunch of my public
> >> repositories. Because, hey, I don't want to directly train the
> >> technologies that will likely destroy the whole economics behind open-
> >> source software development. So I closed off repositories for things
> >> I'd voluntarily made public, including dropping any QGIS plugin that I
> >> wasn't directly using myself anymore, and that wasn't funded or in use
> >> by my customers (or where a better native tool now exists). And that
> >> included the SAGA NextGen plugin. I have no use for it, and none of my
> >> customers use it, and it's a PITA to "maintain".
> >> I knew that by doing so I'd be stirring up trouble, and honestly, that
> >> was partly my intention! I wanted to force a discussion about this,
> >> and raise widespread attention to the issues that would otherwise go
> >> unnoticed. It's the SAGA plugin today, but tomorrow it could easily be
> >> QGIS itself, or GDAL, or PostGIS, or PDAL, or ... 😱
> >> My personal preference would be that we continue to port useful tools
> >> from SAGA to native QGIS versions of these tools. I've done this in
> >> the past (see https://github.com/qgis/QGIS/pull/53794 <https://
> >> github.com/ qgis/QGIS/pull/53794>, https://github.com/qgis/QGIS/
> >> pull/61722 <https:// github.com/qgis/QGIS/pull/61722>) for tools that
> >> I need myself, or that my customers rely on, and the QGIS native tools
> >> are so much better (***FOR QGIS USERS***) then calling out to the SAGA
> >> versions. They have full format support for all the data sources QGIS
> >> supports, they work with massive rasters without memory issues, and
> >> they are much faster as they don't require data conversion to
> >> intermediate formats. And on top of that, they "just work" everywhere
> >> QGIS works -- there's no fussing around with SAGA version
> >> compatibility, and no security risks with python code shelling out to
> >> run random batch files.
> >> (Please understand that I'm not insulting the SAGA developers or their
> >> versions of these tools here... in my experience the SAGA developer's
> >> logic is great, the code is well written and the algorithms themselves
> >> are well designed. It's a testament to the SAGA developers how easy it
> >> is to port the tools to QGIS, they are very readable and well
> >> documented. My point is that we offer a better experience to **QGIS**
> >> users by porting the tools to native equivalents using QGIS API
> >> directly).
> >> If anyone has particular SAGA tools they rely on for their work, then
> >> please reach out and I'll let you know how much it would cost to
> >> sponsor a port of that tool.
> >> Finally, please note that I didn't delete the plugin repository, I
> >> just made it private instead of public. I'm happy to temporarily make
> >> it public again if someone wants to fork it, but after they do that
> >> I'll then permanently erase my repo. If someone wants to do this then
> >> let me know and I'll re-open temporarily.
> >> Nyall
> >>  > According to reports in the QGIS community’s Telegram group,
> >> maintaining this plugin is becoming increasingly difficult due to
> >> developments in the SAGA project, which can cause the plugin to stop
> >> working.
> >>  > I recall that until a couple of years ago, SAGA was, like GRASS, a
> >> resource installed directly within QGIS, but then, precisely because
> >> of the difficulty in keeping up with SAGA’s developments, it was
> >> decided to treat SAGA as a third-party resource accessible via plugins.
> >>  > I believe it is right that this important resource should not be
> >> maintained on a voluntary basis by a single developer/user, but that
> >> it should be taken on by the community.
> >>  > Do you think it would be a good idea to propose to the Steering
> >> Group that its maintenance be taken on directly by the QGIS.org
> >> Foundation and that a certain sum (1000–2000 euros?) be set aside in
> >> the annual budget for its maintenance?
> >>  > Thank you
> >>  > stefano campus
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
___________________________
Sebastian "Bas* " Gutwein
*rhymes with Josh
Regenerative Design Group
1 Chevalier Ave
Greenfield, Ma 01301
Web: regenerativedesigngroup.com
(631) 241-1018
*Look close, think big, make change. *
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260722/bf85a773/attachment-0001.htm>
More information about the QGIS-Developer mailing list
