[QGIS-Developer] Problems uploading a new Plugin version due to homepage supposedly not being reachable
Lova Andriarimalala lova at kartoza.com
Thu Jul 30 00:52:38 PDT 2026
Hi Marco,
Thanks for raising this. It's a temporary issue because the timeout is
likely too short for the plugin infrastructure to check the homepage. I
suggest trying again a few times or opening an issue at
https://github.com/qgis/QGIS-Plugins-Website if it persists. I would be
happy to check this specific case.
Best regards,
Lova Andriarimalala
*QGIS Full Stack Developer   *
*T *: +27(0) 87 809 2702          *E *: lova at kartoza.com          *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Wed, 29 Jul 2026 at 15:32, Marco Lechner via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi,
> I try to upload a new Version of my plugin, but the Check fails with
> “There were errors reading plugin package (please check also your plugin's
> metadata).
> Please provide valid URL link for the following key(s) in the metadata
> source: * homepage*. The website(s) cannot be reached within 10 seconds.“
> In metadata.txt homepage is set to homepage=https://www.bfs.de that
> should be reachable without problems. Any ideas how to fix it? Do I have to
> change anything mor in my metadata.txt or is this a bug in the
> plugin-Infrastructure?
> Regards
> Marco
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260730/d6f0e954/attachment.htm>
More information about the QGIS-Developer mailing list
