[QGIS-Developer] Problems uploading a new Plugin version due to homepage supposedly not being reachable
Marco Lechner mlechner at bfs.de
Thu Jul 30 02:54:19 PDT 2026
Done. See https://github.com/qgis/QGIS-Plugins-Website/issues/406
I would be happy to support fixing this issue with tests, information, …
Regards
Marco
Von: Lova Andriarimalala <lova at kartoza.com>
Gesendet: Donnerstag, 30. Juli 2026 09:53
An: Marco Lechner <mlechner at bfs.de>
Cc: qgis-developer at lists.osgeo.org
Betreff: Re: [QGIS-Developer] Problems uploading a new Plugin version due to homepage supposedly not being reachable
Hi Marco,
Thanks for raising this. It's a temporary issue because the timeout is likely too short for the plugin infrastructure to check the homepage. I suggest trying again a few times or opening an issue at https://github.com/qgis/QGIS-Plugins-Website if it persists. I would be happy to check this specific case.
Best regards,
Lova Andriarimalala
QGIS Full Stack Developer
T : +27(0) 87 809 2702          E : lova at kartoza.com<mailto:lova at kartoza.com>          W : kartoza.com<http://kartoza.com>
[https://erp.kartoza.com/files/KartozaEmailSignatureTest.gif]
This email and any attachments are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you
have received this email in error, please notify the sender immediately and delete it from your system. Unauthorised use, disclosure, or copying
of the contents is prohibited.
On Wed, 29 Jul 2026 at 15:32, Marco Lechner via QGIS-Developer <qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>> wrote:
I try to upload a new Version of my plugin, but the Check fails with
“There were errors reading plugin package (please check also your plugin's metadata).
Please provide valid URL link for the following key(s) in the metadata source: homepage. The website(s) cannot be reached within 10 seconds.“
In metadata.txt homepage is set to homepage=https://www.bfs.de that should be reachable without problems. Any ideas how to fix it? Do I have to change anything mor in my metadata.txt or is this a bug in the plugin-Infrastructure?
Regards
Marco
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org<mailto:QGIS-Developer at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260730/cf7105ef/attachment-0001.htm>
More information about the QGIS-Developer mailing list
