[QGIS-Developer] Problems uploading a new Plugin version due to homepage supposedly not being reachable
Lova Andriarimalala lova at kartoza.com
Thu Jul 30 03:36:38 PDT 2026
> For what it's worth, I tried to open the homepage URL in a browser, got
> a failure, tried with some command line tool (forget), got a failure,
> and then a minute or so later the URL worked in the browser.
Thank you for testing Greg. I am checking it now and it seems to be working
as well (with a redirection to https://www.bfs.de/DE/home/home_node.html).
So the issue is probably from the homepage side.
Best regards,
Lova Andriarimalala
*QGIS Full Stack Developer   *
*T *: +27(0) 87 809 2702          *E *: lova at kartoza.com          *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Thu, 30 Jul 2026 at 13:26, Greg Troxel via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Lova Andriarimalala via QGIS-Developer <qgis-developer at lists.osgeo.org>
> writes:
> > Thanks for raising this. It's a temporary issue because the timeout is
> > likely too short for the plugin infrastructure to check the homepage. I
> > suggest trying again a few times or opening an issue at
> > https://github.com/qgis/QGIS-Plugins-Website if it persists. I would be
> > happy to check this specific case.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260730/ac411475/attachment.htm>
More information about the QGIS-Developer mailing list
