[QGIS-Developer] QGIS 4: PostgreSQL layer properties 'Information from provider' is not displayed correctly
Nyall Dawson
nyall.dawson at gmail.com
Mon Jun 8 16:59:16 PDT 2026
On Fri, 5 Jun 2026 at 22:58, Rainer Hurling via QGIS-Developer
<qgis-developer at lists.osgeo.org> wrote:
> Dear Devs,
> I was unable to attach a screenshot to a GitHub issue. Therefore, I am
> describing the following issue here in the list, as it is difficult to
> describe the error without an image.
> In QGIS 4, in released versions up to 4.0.3 as well as in today's devel
> branch, the “Information from provider” section in the properties of
> PostgreSQL layers is displayed incorrectly. This happens in the browser
> and also with loaded layers.
> Instead of the expected information under Privileges or Spatial Index, a
> list of dots is displayed. Each dot in the list contains exactly one
> character. All characters in a list appear to be SQL commands or
> parameters? The attached screenshot shows a section where the display
> error can be seen.
> This occurs on Windows 10, 11, and FreeBSD. In QGIS 3, the properties of
> PostgreSQL layers are displayed correctly.
Fixed in https://github.com/qgis/QGIS/pull/66402
Nyall
> Best regards,
> Rainer_______________________________________________
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
