[QGIS-Developer] QGIS 4: PostgreSQL layer properties 'Information from provider' is not displayed correctly
Rainer Hurling
rhurlin at gwdg.de
Wed Jun 10 08:55:49 PDT 2026
Am 09.06.26 um 01:59 schrieb Nyall Dawson:
> On Fri, 5 Jun 2026 at 22:58, Rainer Hurling via QGIS-Developer
> <qgis-developer at lists.osgeo.org> wrote:
>> Dear Devs,
>> I was unable to attach a screenshot to a GitHub issue. Therefore, I am
>> describing the following issue here in the list, as it is difficult to
>> describe the error without an image.
>> In QGIS 4, in released versions up to 4.0.3 as well as in today's devel
>> branch, the “Information from provider” section in the properties of
>> PostgreSQL layers is displayed incorrectly. This happens in the browser
>> and also with loaded layers.
>> Instead of the expected information under Privileges or Spatial Index, a
>> list of dots is displayed. Each dot in the list contains exactly one
>> character. All characters in a list appear to be SQL commands or
>> parameters? The attached screenshot shows a section where the display
>> error can be seen.
>> This occurs on Windows 10, 11, and FreeBSD. In QGIS 3, the properties of
>> PostgreSQL layers are displayed correctly.
> Fixed in https://github.com/qgis/QGIS/pull/66402
Many thanks. It works again as expected.
> Nyall
>> Best regards,
>> Rainer_______________________________________________
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
