[QGIS-Developer] Rights to merge Pull Request even if CI is red
Even Rouault even.rouault at spatialys.com
Thu Jun 25 04:39:19 PDT 2026
Hi Nyall,
your answer doesn't really answer my question :-) Is the restriction for
every committer or a subset?
Who has rights for changing qgis/qgis github settings? (not necessarily
asking for them to be extended, but just so we know). It would be good
to communicate when some settings that might affect workflows are adjusted
I'd say that we should probably give up for now to auto-merge if it
blocks approved pull requests from being merged
Even
Le 25/06/2026 à 13:30, Nyall Dawson a écrit :
> On Thu, 25 June 2026, 9:24 pm Even Rouault via QGIS-Developer,
> <qgis-developer at lists.osgeo.org> wrote:
>     Hi Julien,
>     I just tried looking at your PR [0] and I also don't seem to have the
>     right to force merge it (only "auto-merge" rights that depend on
>     green CI)
>     It would be indeed great to have some clarification of who might have
>     such rights or not, so we can see if there isn't a bottleneck that
>     must
>     be resolved. I'm not sure why we would want such rights to be
>     restricted
>     to a subset of people with "regular" merge rights rather than the
>     whole
>     group.
> An alternative would be to remove the merge rules which require tests
> to pass -- that'd avoid expanding rights while still allowing the
> blockage to be removed.
> (Downside is that doing this breaks the ability to "auto merge")
> Nyall
>     Even
>     Le 25/06/2026 à 12:24, Julien Cabieces via QGIS-Developer a écrit :
>     > Hi devs,
>     > I cannot merge PR #66483 [0] because there is at least one unrelated
>     > test failure every time the CI is launched (I restarted it 7
>     times), although the PR was approved
>     > 6 days ago.
>     > I have already tackled the issue of the test_gui_fileuploader
>     [1] which was
>     > failing very often recently because of badssl.com
>     <http://badssl.com> being unstable but there
>     > are now other issues.
>     > A few months ago, I had the rights to merge a PR even if tests were
>     > failing, but I don't have them anymore and I cannot contribute
>     anymore
>     > on #66483 related issues (I have more fix commits based on this PR).
>     > It seems to me that other code committers still have these
>     rights as I see
>     > PRs with a red CI still being merged.
>     > May I have these rights too so I can continue to contribute
>     normally?
>     > Shall every core committer have these rights ?
>     > Kind regards,
>     > Julien
>     > [0] https://github.com/qgis/QGIS/pull/66483
>     > [1] https://github.com/qgis/QGIS/pull/66543
>     http://www.spatialys.com
>     My software is free, but my time generally not.
>     LLMs contribute to global warming and brain rot
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260625/755a5601/attachment-0001.htm>
More information about the QGIS-Developer mailing list
